High boost and low comp or low boost and high comp
Old May 16, 2007 | 02:51 PM
22's and Man Boobs's Avatar
Default High boost and low comp or low boost and high comp
OK so I'm startin to plan out my B series motor build and i'm havin trouble decidin which way to go. It's gonna be turboed and the block and head are gonna be completely built, stroked, and bored over, including sleeves and bigger head studs... But anyways, the compression ratios i was thinkin about using were either:
1) 7.1:1
or
2) 14.x:1
Your thoughts and comments are greatly appreciated... Thanks
Old May 16, 2007 | 03:04 PM
Schister66's Avatar
Man U FTW
i have never heard of anyone using a 7:1 compression piston in a turbo Honda...and i dont think you'd have much room to boost on a 14:1 compression engine...maybe think of something a little less extreme
if you want to have good off-boost response, get something in the 11:1 range or if you want lower comp, get a 9.6:1 piston...there is no need to go to 7:1 or 14:1
Old May 16, 2007 | 03:22 PM
Default Re: (Schister66)
i know what your sayin, but i'm definatly goin for extreme... somethin even the hardcore hondacura haters will respect
Old May 16, 2007 | 03:27 PM
doood's Avatar
been there done that
Default Re: (DoWorkSon22)
is this thing a track only methanol guzzling setup?
Old May 16, 2007 | 03:57 PM
Default Re: (doood)
street/strip... 2 fuel tanks tanks (one 93 oct and one race gas) with 2 ecu maps...
MyEvo
Oct 6, 2005 05:14 AM
rb08
Aug 26, 2003 07:52 AM
NXAccordTO4B
Mar 20, 2003 09:01 PM
AzN_Flava
May 12, 2002 05:35 PM
