injector question..
Old May 16, 2007 | 12:22 PM
swt_666's Avatar
Default injector question..
when looking for injectors i notice some cars say "peak and hold" others say "saturated" ...... what do these terms mean?
Old May 16, 2007 | 01:03 PM
dpaton's Avatar
Default Re: injector question.. (swt_666)
It refers to the way they're activated, kinda. The P&H injectors need a resistor box, because they use high current coils, and will fry an ECU without the extra resistance. The Saturated injectors are direct-drive because they use a higher impedance coil. Saturated injectors can also puls a leeeeetle bit faster because of their electromechanical design (this is a rule of thumb, not an absolute).
Old May 16, 2007 | 09:33 PM
1CamSol's Avatar
Don't call other people bad names out of anger. It only shows ignorance.
Default Re: injector question.. (dpaton)
Saturated injectors are high impedance and P&H are low impedance injectors. P&H will draw ~4A from the stock driver w/o a resistor pack. This will fry the driver which is made for saturated injectors which are made to handle only ~1A of current. Hence the need for the resistor pack to make it 'look' like a saturated injector.
BoostinTEG
Jan 22, 2011 06:34 AM
prelude2121
Oct 29, 2010 02:40 PM
cameron4776
Sep 22, 2007 05:33 PM
nolicense526
Jul 31, 2007 06:17 AM
dkdjlf
Sep 19, 2003 02:31 AM
