BURST WATER LINE TO TURBO. HELP!!!! (PICS)
Old May 16, 2007 | 10:05 AM
Willie's Avatar
Default BURST WATER LINE TO TURBO. HELP!!!!
Ive burst a water line that runs to my gt28rs today. Both lines are T off the IN and OUT pipes to my heater, but the one that has burst is the one on the right which 'ISNT' T off the the heater line with the valve on it. The line that is T off the valve is okay. Could it be the fact that the burst line is at an awkward angle creatind to much tension on the line or does the valve have something to do with this. What is the best way to fix this as i need the car for work tomorrow
Modified by Willie at 7:21 PM 5/16/2007
Modified by Willie at 7:46 PM 5/16/2007
Old May 16, 2007 | 10:30 AM
Willie's Avatar
Default Re: BURST WATER LINE TO TURBO. HELP!!!! (Willie)
anyone!!!!!
Old May 16, 2007 | 10:45 AM
Willie's Avatar
bump
Old May 16, 2007 | 10:46 AM
mike1114's Avatar
what kind of line did you use? Possibly the hose just wasn't rated at a high enough pressure.
When I first put an oil cooler on my car, I did not use high press line like in the power steering, it burst and spewed oil all over the road and I did a 360 and came to a stop, was a little scary but I learned my lesson.
After that, I went and bought 300psi line and use that. It was more expensive but it lastet well over a year until my car got stolen.
Vatozone sells high pressure line, just ask for it.
Old May 16, 2007 | 10:52 AM
Willie's Avatar
its braided stainless steal. the other line is okay. does it have something to do with the valve for hot and cold on the heater hose, im stumped
Old May 16, 2007 | 11:25 AM
Willie's Avatar
Default Re: (Willie)
have i screwed things up using the heater lines
Old May 16, 2007 | 11:47 AM
Willie's Avatar
ttttt
Old May 16, 2007 | 12:55 PM
Willie's Avatar
c'mon guys
stackz
Feb 28, 2008 01:49 PM
themorphious
Jun 11, 2006 09:18 PM
HamiltonRex
Apr 17, 2006 05:17 PM
GraphiteAccord
Jun 17, 2003 11:18 AM
Diego Boost
Mar 10, 2003 01:20 PM
