Tokico Illuminas (5-way) shocks
Old May 16, 2007 | 12:33 AM
SkRoMeEnIzANoNo's Avatar
Default Tokico Illuminas (5-way) shocks
ur opinion.. what set up on these shocks.. i got it on #3 all around... what feels good on the street and freeway?
Modified by SkRoMeEnIzANoNo at 1:45 AM 5/16/2007
Old May 16, 2007 | 05:25 AM
godofcheese's Avatar
Default Re: Tokico Illuminas (5-way) shocks (SkRoMeEnIzANoNo)
just play around with them. What feals good to one person isn't to another person. I drive around on 2 or 3, but knock it up to 4-5 for autocross. Of course, then I forget to switch it back and drive around town on 5 for a few weeks before someone complains.
Old May 16, 2007 | 07:05 AM
SlobberGoat's Avatar
Default Re: Tokico Illuminas (godofcheese)
mine are 5 all way round...
Old May 16, 2007 | 08:52 AM
omgwtfbbqcrx's Avatar
i use 5 all the way
Old May 16, 2007 | 03:45 PM
WindyCity's Avatar
Daily driving on 3 F&R feels good.
Old May 17, 2007 | 06:53 AM
gringo7718's Avatar
Default Re: (WindyCity)
5 - Full stiff at all times, but with tein stech (soft springs) it is pretty comfortable.
Old May 17, 2007 | 11:34 AM
NastyHabitzCRX's Avatar
front 3 rear 5. up the front to for "track" use
Old May 17, 2007 | 03:14 PM
Tyson's Avatar
what you set your shocks at should be determined by your springs and your use (daily, fun runs, race). and not by anyone else's opinion.
for the street, i will find a speed bump and go over the speed bump at a slow, but moderate speed. i will try to find the setting that will comfortably settle, going up and over and especially after the bump. specifically i mean it will bounce once and then no more. start at the #1 position and work your way up until it no longer bounces then dial it back one. do front and rear separately.
ive set this once and have not changed it since, as long as i daily drive my car.
for the track or performance use, i set it at 4 all the way around and TUNE the car from there. if i want a bit more oversteer, bump the rear up to 5, or reduce the front to 3. if i want less oversteer, then i bump the front up to 5, or reduce the rear. if both are set at 5, then i reduce the end that i want more grip. thats the general rule of thumb in suspension tuning.
again, what anyone else has to say what they set their shocks at is irrelevant to me, and should be to you.
Old May 17, 2007 | 06:50 PM
Default Re: Tokico Illuminas (Tyson)
i jus want to know what gives me the most traction for drag racing... but i have a feeling even if i do different combinations it wont even take a tenth of a sec off my times hahhah
but ill try out what u guys said
thanks
Old May 17, 2007 | 06:52 PM
Tyson's Avatar
Default Re: Tokico Illuminas (SkRoMeEnIzANoNo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRoMeEnIzANoNo &raquo;</TD></TR><TR><TD CLASS="quote">ur opinion.. what set up on these shocks.. i got it on #3 all around... what feels good on the street and freeway?
Modified by SkRoMeEnIzANoNo at 1:45 AM 5/16/2007</TD></TR></TABLE>
you didnt even mention drag racing...
having no personal experience drag racing, id set the rears to full stiff, and start from 1 in the front and work my way up until i start losing traction.
bigdogadam
Jan 13, 2009 08:07 PM
AcuraKid
Suspension & Brakes
Jun 4, 2005 05:25 AM
Mr_EmO
Apr 26, 2005 03:24 AM
Si Arn
20
Apr 4, 2004 01:05 AM
xcathodex
24
Feb 13, 2003 05:11 PM
