What motor mount will work?
I did a h22a4 swap into my 92 prelude and I have the front mount, driver and passenger mounts bolted up nicely but the bracket that sticks off of the h22a4 block does not match up right with the prelude rear engine mount. It is way off! like a couple inches!
When I drive the car it is way shaky, and the motor shifts in the bay ALOT!
When I drive and say im in gear and just let off the gas it like thuds the motor back hard, then starts slowing down
Does anybody know what mount I am going to need to make this work?
Maybe one off of an accord or something? Or do I need to swap a crossmember or something?
Or am I gonna need to use the rear bracket off of the h23?
If your looking for stiffer engine mounts, go on ebay and buy Prelude Energy suspension motor mount inserts
They are only 40 bucks shipped and the best thing you can get for preludes for wheel hop, and the engine moving to much in he bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc »</TD></TR><TR><TD CLASS="quote">If your looking for stiffer engine mounts, go on ebay and buy Prelude Energy suspension motor mount inserts
They are only 40 bucks shipped and the best thing you can get for preludes for wheel hop, and the engine moving to much in he bay.</TD></TR></TABLE>
yea thats what I was thinking, do you think those motor mount inserts will compensate for the missing rear mount?
no the inserts are for the front and rear mounts. how did you come across the rear bracket/mount? did they come with the engine or did you have them before the swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvteclude »</TD></TR><TR><TD CLASS="quote">no the inserts are for the front and rear mounts. how did you come across the rear bracket/mount? did they come with the engine or did you have them before the swap?
I kept the rear mount from my 92 prelude on the car itself, the bracket that is bolted to the block is from the 01 prelude. Are the brackets different from the 4th and 5th gen?
Or is the bracket mounted somewhere elso on the h23 block? Please help asap thanks!
sorry to thread jack, but i'm also wondering, are all prelude motor mounts interchangeable while the engine is in the car (with simple jack positioning beneath the engine) or is there a mount that requires the engine be fully removed to change?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altilude »</TD></TR><TR><TD CLASS="quote">sorry to thread jack, but i'm also wondering, are all prelude motor mounts interchangeable while the engine is in the car (with simple jack positioning beneath the engine) or is there a mount that requires the engine be fully removed to change?
The rear is a bitch with the intake manifold on still, but none of them require the engine to be removed.
bump, I looked up on Jrcormier.com and when he did his h22a4 swap he said that he only needed to swap his side mounts, and that he got the front and back in just fine.
WTF?
IS MY PRELUDE JUST GAY OR SOMETHING???
SOMEONE PLZ HELP ME!!!
WTF?
TearSDMF89dx
Feb 15, 2012 02:52 PM
onyx00
Sep 24, 2004 01:00 PM
