losing oil fast-
Old May 15, 2007 | 06:45 PM
primetime's Avatar
Default losing oil fast-
So I checked my oil the other day and it was low, I added a quart, drove about 350 miles and now the dip stick says I need another quart. Any one else experience this problem or have any insight car=2002 rsx type 2 w/105,000 miles. Maintance is performed regualarly.
Old May 15, 2007 | 08:37 PM
WhiteOnRice's Avatar
Just started doing this or every oil change? Check your oil plug or filter. Maybe someone did a lazy oil change...
Old May 15, 2007 | 08:56 PM
primetime's Avatar
Default Re: (WhiteOnRice)
yeah it just started doing this. Actually a little over due on the oil change this time. haven't really looked for a leak though.
Old May 15, 2007 | 10:33 PM
handicapable's Avatar
Default Re: (primetime)
You need to look for a leak and because you are losing a considerable amount of oil it should be easy to spot one. You could start by checking for leaks on the pavement under your car.
If not you could be burning so check to see if the exhaust gas is blue.
Old May 16, 2007 | 03:35 AM
primetime's Avatar
Default Re: (handicapable)
yeah checked under the car when I first discovered this no leaks in my parking spot. Also haven't seen smoke and it does not smell like buring oil either ( my turbo civic used to burn oil ) It is like someone is draining my oil at night really wierd.. I will be doing a oil change next week will be under the car then to look more closly for a leak.
Old May 16, 2007 | 06:30 AM
How many quarts have you put in total? Your last oil change plus additional oil?
Old May 16, 2007 | 07:48 AM
T_Virus's Avatar
Other than that, stop hitting Vtec so much...I know it is addictive but some how with the K-series motor, it tends to eat more oil when your in Vtec...My buddie with a type s is starting to have the same problem your having while for me with my a3 motor, it eats alot of oil only if I stay in the high rpms too long or push it too much...don't know why..
Old May 16, 2007 | 02:36 PM
Check the colors of all your other fluids cause it could be leaking into one of them.
Old May 17, 2007 | 06:23 AM
Rs-xtacy's Avatar
Default Re: losing oil fast- (primetime)
Get your oil changed and see what happens, you know that its really low when your timing belt tensioner starts smacking. check your drain plug and how tight your oil filter is. Just dont drive without oil in it.
Old May 17, 2007 | 06:25 AM
Rs-xtacy's Avatar
Get your oil changed and see what happens, you know that its really low when your timing belt tensioner starts smacking. check your drain plug and how tight your oil filter is. Just dont drive without oil in it. If you dont get it fixed right away, your v-tec wont kick in if you dont have enough oil. If u expierence it not working make sure you put some oil in it. I would be extra careful untill you get it figued out because k20 motors arent cheap.
Old May 17, 2007 | 11:10 AM
Code's Avatar
Not now Chief, I'm in the F'n zone!
Is your car smoking under accelleration?
nick_622
Honda Civic (2001 - 2005)
10
Apr 20, 2009 04:54 PM
stevanrk
Aug 31, 2008 05:09 PM
chuckus
Oct 22, 2004 02:45 PM
boostcontroller
Jun 27, 2003 06:53 AM
Puki
May 19, 2003 11:56 AM
