B16 Cable Trans. VSS Wont Come Out. Where To Fill With Oil?
Old May 15, 2007 | 06:30 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default B16 Cable Trans. VSS Wont Come Out. Where To Fill With Oil?
In my hatch, my b16 obd0 cable trans cluthc **** the bed, I swapped it out, but couldnt get the VSS disconnected so I just unhooked it from the dash. Now since I cant get the VSS out, where do I fill with oil?
Also, about not being abel to get the vss out, the whole VSS thing looks weird, its got 2 prongs on it but nothing going to them, and there a 10mm bolt below it. Does it come apart soehow? Are those lines supposed to get used?
Old May 15, 2007 | 06:40 PM
Eran's Avatar
HT White Ops
There should be a vent pipe at the top (it looks like a hollow metal dowel). I use a 2-liter bottle, a syrup pump (like for espresso syrup), and a clear silicone hose. I then pump the fluid into the transmission from there.
Old May 15, 2007 | 06:43 PM
PINKS's Avatar
Default Re: (Eran)
Well im not loking at it now, but where my VSS was, there was 2 copper type barbs coming out. do they lead into the right spot?
I dont wanna screw this up
Old May 15, 2007 | 07:02 PM
Padawan's Avatar
Darth ModerVader
Default Re: B16 Cable Trans. VSS Wont Come Out. Where To Fill With Oil? (PINKS)
Just fill via the fill hole using a funnel and some tubing.
Old May 15, 2007 | 07:14 PM
PINKS's Avatar
Default Re: B16 Cable Trans. VSS Wont Come Out. Where To Fill With Oil? (Padawan)
I didnt even see a freakin fill hole lol. I dont thinkt I can access it in my chassis anyways. Any quick way form the top?
Old May 16, 2007 | 04:43 AM
Padawan's Avatar
Darth ModerVader
Well, you need to access the fill hole anyway in order to ensure that you have the correct amount of fluid in the transmission. You should fill it until the fluid beings to overflow out of the hole.
Old May 16, 2007 | 05:19 PM
PINKS's Avatar
Theres a barb ontop of my trans to the right front of the clutch cable bracket, b[probably 1/2" ID and 2" sticking out"
Does it lead into the trans?
Old May 16, 2007 | 05:23 PM
Padawan's Avatar
Darth ModerVader
I'm having trouble envisioning what you're describing, but again, you're going to have to open the fill hole regardless in order to properly fill the transmission.
Old May 16, 2007 | 05:27 PM
PINKS's Avatar
No you dont have to open no fill hole, as I dont even see one, Ive got 3 plugs on the side of my trans, one is the drain plug, one is a 8mm plug that leads to a clip of some sort but the hole is blocked off, and a 3/8" ratchet plug to another blocked off hole
I know how much oil the tranny takes, so I just need to know what passage from the top leads to where im going!!
Old May 16, 2007 | 05:28 PM
hatchling37's Avatar
Does this help? (Don't know if this pic is showing up, please let me know if it is not...)
Modified by hatchling37 at 7:38 PM 5/16/2007
Old May 16, 2007 | 05:38 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">No you dont have to open no fill hole, as I dont even see one, Ive got 3 plugs on the side of my trans, one is the drain plug, one is a 8mm plug that leads to a clip of some sort but the hole is blocked off, and a 3/8" ratchet plug to another blocked off hole
I know how much oil the tranny takes, so I just need to know what passage from the top leads to where im going!!</TD></TR></TABLE>
There is definitely a fill hole on your transmission (see the photo posted above), and if you want to end up with the correct fluid level, you should use it. If you want to simply estimate using a certain set amount of fluid, that's fine, but it isn't the recommend method and could result in an under- or over-filled transmission.
Old May 16, 2007 | 05:42 PM
PINKS's Avatar
Aint nothing there, lookin right at it. Definetely nothing on the side
Old May 16, 2007 | 05:44 PM
Padawan's Avatar
Darth ModerVader
Can you post a photo?
scooterbuilteh2
Jan 9, 2010 04:38 PM
PINKS
13
Aug 3, 2007 07:44 PM
teler86
Jan 26, 2006 06:47 PM
teler86
Mar 16, 2005 09:39 PM
