b16 Cable tranny
about 2 1/4-2 1/2 quarts depending on if you have the car lifted from the front or not.....the drain bolt is on the bottom right side of the tranny(passenger side)..use a 3/8 ratchet with no socket to loosen it..the fill hole is by the right axle its a 17MM head bolt..you have to use either a pump or a long funnel from the top to fill it...use only HONDA MTF..alot of people use motor oil but i use MTF....
ever'sneighborhood
20
Jul 26, 2011 11:51 AM
roycivic92
Nov 14, 2005 11:03 AM
