Accord 2005 CEL 1902???
Old May 15, 2007 | 05:11 PM
codenamezero's Avatar
Default Accord 2005 CEL 1902???
Hey guys i just checked out the CEL code, but i got 19 long flashes, and 2 short flashes. (there is a really short pause between the long and short, i think that MIGHT be a zero...)
So is either P1902 or P192 but i've check all over the place there is no such code.
The code came out after an oil change.
Any idea??
edit: hum can it also be P0192??
P0192 Fuel Pressure Sensor Circuit Low Voltage
Modified by codenamezero at 4:14 AM 5/16/2007
Old May 15, 2007 | 08:05 PM
JimBlake's Avatar
Default Re: Accord 2005 CEL 1902??? (codenamezero)
You're confusing the flash code numbers with the OBD-2 codes. They're separate lists.
Still, 19 long flashes isn't in any list I've seen. And the short pause isn't a zero. Try watching it again, or go to AutoZone & use a code reader.
Old May 15, 2007 | 10:09 PM
no autozone here. i couldnt find the code for 19 long and 2 short either. but i follow the code reading trick from RSX, it should be the same.
Old May 16, 2007 | 04:15 AM
JimBlake's Avatar
Default Re: (codenamezero)
Any kind of parts stores like that? PepBoys, CanadianTire, ???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by codenamezero &raquo;</TD></TR><TR><TD CLASS="quote">... but i follow the code reading trick from RSX, it should be the same.</TD></TR></TABLE>What's that trick?
Old May 16, 2007 | 07:12 PM
http://www.k-series.com/tech_d...D=CEL
Old May 16, 2007 | 07:51 PM
JimBlake's Avatar
Looks like the right procedure. That's the CEL flash codes from the first column of the DTC index. I don't have a new-enough list to help you.
Old May 16, 2007 | 08:08 PM
yea i had been searching for over 2 hours on google, but couldnt find anything that's why i post it here hoping someone might know.
soodominican
Aug 12, 2009 12:48 PM
nEoMuGen
Jul 23, 2007 08:42 PM
GsrVtec
Oct 19, 2006 07:33 AM
dreams190
Apr 1, 2005 07:03 AM
ImprtTunr
Jul 12, 2002 01:47 PM
