D15B????
Hey i was wondering if anyone knows what a D15B is in US!! I mean is it a VX model or what !!!!? Also does the Thermostat on a VX open at diffirent temp then a EX LX ETC!! Thanx for any input guys
Ok but see this is my problem somehow my engine swap is heating up fast i mean FAST as in two blocks driving! And somehow the thermostat has not opened when i check it!!! What could be wrong? Ive changed thermo 2 times now and still not working any other ideas
car is heating up fast? you say you swapped this motor in? does it have a vtec silinoid(dont know if that is how you spell it or not). umm have you double checked all your fluids, oil, radiator,tranny? any codes, from the ecu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat »</TD></TR><TR><TD CLASS="quote">car is heating up fast? you say you swapped this motor in? does it have a vtec silinoid(dont know if that is how you spell it or not). umm have you double checked all your fluids, oil, radiator,tranny? any codes, from the ecu?</TD></TR></TABLE> No codes and fluid is fine but like i said its not flowing water for some reason! also my pump is new alot of the **** in it is new!! i mean what did i do wrong!? Also my dad ran it for about 10 min. with no thermo and no problem i mean WTF
Do you know if there is any diffirence in thermo opening temps for a D15B or whatever you said it was!!!
Ah and yes it has vtec solenoid but is not hooked up yet since i havent change the ecu!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR »</TD></TR><TR><TD CLASS="quote">air in coolant??</TD></TR></TABLE>
x100000, bleed your coolant for along time with the heat on max
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock »</TD></TR><TR><TD CLASS="quote"> No codes and fluid is fine but like i said its not flowing water for some reason! also my pump is new alot of the **** in it is new!! i mean what did i do wrong!? Also my dad ran it for about 10 min. with no thermo and no problem i mean WTF
Ah and yes it has vtec solenoid but is not hooked up yet since i havent change the ecu!!!</TD></TR></TABLE>
well with it haveing a vtec solenoid then it is prob a d15b(jdm) or a d16z6. oh and if it is the coolent thingy, with air bubbles than that is no big deal and just turn your heat all the way up, or have your car idle with the coolent cap off and heat all the way up.
Ah and yes it has vtec solenoid but is not hooked up yet since i havent change the ecu!!!</TD></TR></TABLE>well with it haveing a vtec solenoid then it is prob a d15b(jdm) or a d16z6. oh and if it is the coolent thingy, with air bubbles than that is no big deal and just turn your heat all the way up, or have your car idle with the coolent cap off and heat all the way up.
thatnikkashoD
Oct 31, 2007 07:46 AM
ScubaSteveSi
34
Aug 13, 2007 05:00 PM
EGhatched
Nov 19, 2003 09:29 PM
