Honda S2000 Honda S2000
Too much Honda Bond?
Old May 15, 2007 | 01:22 PM
J.nguyen's Avatar
Default Too much Honda Bond?
i applied honda bond evenly to the oil pan and ALSO the surface of the mating area of the block that touches the oil pan.. is this too much?
what happens to honda bond if it gets into the oil?
anything to worry about?
Old May 15, 2007 | 05:01 PM
MidwestAutoWorks's Avatar
Default Re: Too much Honda Bond? (J.nguyen)
lol
you will be just fine, although that is a lot you will be fine. Oil wont break down hondabond so it wont fall into pieces into your pan.
Old May 15, 2007 | 06:23 PM
J.nguyen's Avatar
Default Re: Too much Honda Bond? (MidwestAutoWorks)
never ever used honda bond in on my previous 4 integras.. lol s2k's dont have a gasket so..
aites thanks 4 the info
Old May 15, 2007 | 06:43 PM
you must have had that stuff oozing everywhere after you mated the pan to the block. I just put a small amount on the pan and got oozing
Old May 15, 2007 | 08:28 PM
iHATEspeedbumps.'s Avatar
so im guessing you received the oil pan?
Old May 15, 2007 | 10:03 PM
J.nguyen's Avatar
Default Re: Too much Honda Bond? (iHATEspeedbumps.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHATEspeedbumps. &raquo;</TD></TR><TR><TD CLASS="quote">so im guessing you received the oil pan? </TD></TR></TABLE>
yeah, thanks man
Old May 15, 2007 | 10:17 PM
WowOzYouRock's Avatar
whos got another oil pan for sale... i need it to boil pasta... its easier cuz all you need to do is remove the drain bolt to drain the hot water out.. you just need some rachet and socket in your kitchen top... ROFL
mathoffmanrules
Dec 12, 2007 01:41 PM
RHDintegXsi
Jun 17, 2006 04:20 AM
JDM-EJ1
Oct 21, 2004 03:57 AM
DevLishPlaya
Feb 13, 2004 01:52 PM
98 Ek LsVtec
Jul 29, 2001 11:13 AM
