Help changing piston rings
Old May 15, 2007 | 11:03 AM
carbonfib's Avatar
Default Help changing piston rings
I just bought a 92 honda civic hatch.B18 D1. the guy i got it from ran nitrous threw it and the rings need to be changed pretty baddly.. i have helped my friends chanaged the rings in his acura teg. and i have a few friends that are going to help.. but i dont know exactly what i need like what kind of rings, bearings, ext..
Old May 15, 2007 | 02:38 PM
sauceja's Avatar
Default Re: Help changing piston rings (carbonfib)
Inspect bearings - if bad or worn replace.
Hone - can do it yourself with a ball hone to deglaze cylinders. Don't make bigger just a degalzing.
Remove old rings.
Clean pistons
Measure and gap top 2 new rings per cylinder, the oil control rings don't get gapped.
Make sure you align rings correctly.
For gaps and clearances you will need a helms manual or this:
https://honda-tech.com/zerosearch
Old May 15, 2007 | 03:55 PM
postman's Avatar
Default Re: Help changing piston rings (sauceja)
^ short and sweet. one of the better posts
only thing i would reccomend is replace the bearings regardless
Old May 15, 2007 | 05:59 PM
sauceja's Avatar
Default Re: Help changing piston rings (postman)
I replaced my bearings but expect to pay 0.69 for plastiguage and just under 300.00 for oem bearings.
Judge Owens
11
Mar 16, 2014 09:54 AM
nico91civic
Apr 20, 2009 05:54 PM
4EN[sic]
Aug 9, 2007 04:19 AM
vw-honda-hatches
Apr 20, 2003 12:42 AM
