help with catchcan/pcv setup???
Old May 15, 2007 | 09:56 AM
killerpenguin21's Avatar
Default help with catchcan/pcv setup???
built ls/vtec going into 97 ek coupe.
my block did not come with the black box breather, and i dont see the nipple ( i know some years didnt have this setup).
i know ls/vtecs pretty much need something to help the blowby etc. so what would you run?
id like to run a catchcan, but im not quite sure how to hook it up, i dont think the big nipple on the vc to can to intake will do much to replace the pcv...
any help is greatly appreciated!
Old May 15, 2007 | 10:32 AM
SiB16A's Avatar
Default Re: help with catchcan/pcv setup??? (killerpenguin21)
which blocks come with the black box and which didnt?
Old May 15, 2007 | 12:47 PM
Default Re: help with catchcan/pcv setup??? (SiB16A)
im not positive which was which. i just no when i bought my block the guy didnt have it so im not sure if mine had it originally or not.
i think i need to run a line from where the pcv box connects to the manifold but im not sure...wish i could afford the endyn breather.
bump.
Old May 15, 2007 | 02:05 PM
ok so after reading alot...i found my block never had the black box (the big hole is plugged).
so whats my best bet on a catch can for my high comp motor? should i do two fittings on the front of the valve cover?
Old May 15, 2007 | 03:57 PM
postman's Avatar
should be a port on the back of the block to tap into
Old May 16, 2007 | 02:40 AM
haveaNOSday's Avatar
just run the 2 hoses to a catch can with an little air filter and eliminate the pcv system all together. I have an obd1 with the black breather box and i'm running the 2 hoses from the little box and the one on the vlv cover to a catch can, thats it thats all. **** the pcv, scavaging crankcase fumes is so low performance. I will be drilling the holes even bigger eventually to run bigger lines for even more cc ventilation. but doing this won't pass smog test.
Old May 16, 2007 | 06:53 AM
89EF_Turbo's Avatar
Default Re: (haveaNOSday)
There are 2 plugs on the back of the block in the oil return passages that can be removed and replaced with a different plug, one that has a threaded hole in the center that's usually used for some type of temp sensor (such as a rad fan switch). There's an article somewhere on here that elaborates on it for a pcv/catchcan setup, do a search for it and you should find it.
Old May 16, 2007 | 08:05 AM
Default Re: (89EF_Turbo)
yeah i figured that out too bad they are hella stuck in there.
93 Eg Couper
Oct 4, 2010 01:24 AM
My_EFsedan
Dec 20, 2009 09:00 AM
jdmdohcek98
13
Jan 1, 2009 07:55 PM
revolt_allmotor
Oct 29, 2006 07:31 AM
Options
27
Feb 3, 2005 09:14 AM
