Optimum Ride Height for DC5?
Old May 15, 2007 | 01:35 AM
c 2's Avatar
c 2
Default Optimum Ride Height for DC5?
Hey all,
In all your opinions, what is the overall best ride height from stock to improve the DC5's handling? In relation to suspension mobility improvements.
All suggestions welcome
Old May 15, 2007 | 07:42 AM
Todd00's Avatar
I said I don't want a title!
Default Re: Optimum Ride Height for DC5? (c 2)
From my experience, you want to lower the car about 1.5" As soon as you start moving over 1.75" to 2" lower, the handling starts to decline, regardless of the lower cg.
This has to do with the shock travel up front and the geometry of the tierods (bump steer). Also, the rear end geometry really starts to go bad in that you start to experience shock binding.
A low DC5 also has a roll center that is 'below ground', which is not very ideal.
http://e30m3performance.com/my...2.htm
Old May 15, 2007 | 08:07 AM
K20 INSIDE's Avatar
Default Re: Optimum Ride Height for DC5? (Todd00)
1.75 in front 2.00 in rear
Old May 15, 2007 | 09:25 AM
Todd00's Avatar
Default Re: Optimum Ride Height for DC5? (K20 INSIDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20 INSIDE &raquo;</TD></TR><TR><TD CLASS="quote">1.75 in front 2.00 in rear</TD></TR></TABLE>
The rear should actually be higher on these cars if you want a car that'll actually rotate.
Old May 16, 2007 | 11:37 AM
david11's Avatar
would 1.5 still need new struts? i was planning on lowering mine in a few a weeks..and i want to do it the right way but i dont want to afford coilovers..
Old May 16, 2007 | 11:44 AM
Todd00's Avatar
Default Re: (david11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david11 &raquo;</TD></TR><TR><TD CLASS="quote">would 1.5 still need new struts? i was planning on lowering mine in a few a weeks..and i want to do it the right way but i dont want to afford coilovers..</TD></TR></TABLE>
With lowering springs and OEM struts, there is no 'right way'.
Old May 16, 2007 | 11:54 AM
DC5Tuner's Avatar
Todd...is 1.5'' drop the ideal drop on a stock DC5 or one with extended ball joints like the ones you made?
I'm running an ITR setup (which sits about .75'' lower then the USDM Type-S if I recall) and with your extended ball joints couldn't I lower it about 2'' before I start to see any negitive effects because the ITR suspension layout is probably perfectly engineered from honda so that's .75'' off the factory USDM spec ride height + another 1.25-1.5'' from your extended ball joints?
Trying to figure out what would be the best as well.
Old May 16, 2007 | 12:29 PM
Todd00's Avatar
Default Re: Optimum Ride Height for DC5? (DC5Tuner)
I think you have me confused with the guy on clubrsx who made those.
But remember, shock travel is just as important as maintaining suspension geometry.
Old May 16, 2007 | 12:55 PM
DC5StylZ's Avatar
i think tein s techs give u an optimal drop.. looks wise
Old May 17, 2007 | 08:08 PM
DC5Tuner's Avatar
Ha, I think I must've! Didn't think there would be two Todds on the DC5 forum who actually knew what they were talking about suspension wise, lol!
What a coincidence!
Old May 17, 2007 | 09:05 PM
type-G's Avatar
I'm about to buy the tein S, but i can only find it for the 02 04 years do they still fit on my 05 ? it drops the front 1.7 and the rear 1.4 inches. does that sound like anything i should go for?
Old May 18, 2007 | 04:53 AM
Todd00's Avatar
Default Re: Optimum Ride Height for DC5? (type-G)
S-Techs are probably the best DC5 lowering spring out there.
Lowering is about perfect and springrate is spot-on for a good handling car. Put them with a set of Koni shocks and your DC5 will be an incredible handling car.
Old May 18, 2007 | 05:30 AM
type-G's Avatar
but will the 02 04 tein s fit on my 05? and does 1.7 front and 1.4 rear sound like a good drop?
Modified by type-G at 7:04 AM 5/18/2007
Old May 18, 2007 | 05:57 AM
Todd00's Avatar
Tein makes s-techs for the 05-06 RSX. And yes, the lowering of the Teins is fine.
Old May 18, 2007 | 06:08 AM
type-G's Avatar
where can i find it for the 05? every place i looked at only had it for the 02 04.
thanks for your help.
Old May 18, 2007 | 08:22 AM
K20 INSIDE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">
The rear should actually be higher on these cars if you want a car that'll actually rotate. </TD></TR></TABLE>
i'm not saying inches dropped i'm talking about inches off the ground
Old May 18, 2007 | 01:31 PM
black92DA's Avatar
how well does the mugen ss work with the dc5?
Old May 18, 2007 | 02:09 PM
Todd00's Avatar
i'm not saying inches dropped i'm talking about inches off the ground</TD></TR></TABLE>
What/where are your measurements taken from? No way those are jackpad to ground measurements, which is somewhat the norm when it comes to ground/chassis measurements.
ffejufo
Apr 21, 2009 01:45 PM
VeilSide_Mas
22
Aug 5, 2006 06:10 PM
crazydragonclk
Suspension & Brakes
May 24, 2006 10:39 AM
LaOstha
10
Sep 8, 2005 06:45 AM
dubbs
Suspension & Brakes
Aug 26, 2005 05:48 PM
