Front Forks
Front Forks
What front forks can i use that are shorter than my stock ones (ej1,eg) so i can lower my car in the front a lil with out sacraficing loss of suspension travel.
Will you make something up for me please?
Re: Front Forks (LaOstha)
I believe Suspension Techniques has them. I saw them many years ago, they probably still do.
EDIT: Yup. In fact, this article is from a very old issue that I have in my bookcase: http://www.superstreetonline.c.../3334/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superstreet Magazine article »</TD></TR><TR><TD CLASS="quote">Further ride height reduction is gained from Suspension Techniques Drop Forks and front and Pro Arms in back. </TD></TR></TABLE>
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaOstha »</TD></TR><TR><TD CLASS="quote">I was lookin more towards a oem approach</TD></TR></TABLE>
You're out of luck then. Buy air bags if you want to go lower.
be professional
Re: Front Forks (JDM_EK_Fanatic)
If you are using regular dampers with a fixed perch or coilover sleeves (and not threaded-body dampers), you could try cramming the damper down into the fork as far as it will go. Details on how to do this properly can be found here:
https://honda-tech.com/zero...35428
https://honda-tech.com/zero...11166
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_Fanatic »</TD></TR><TR><TD CLASS="quote">If i'm not mistaken, arent the CRX forks shorter?</TD></TR></TABLE>
They are the same length, but have smaller diameter. The EF dampers themselves are shorter.
