lubeing chain
Old May 14, 2007 | 08:32 PM
Tenacious T's Avatar
Default lubeing chain
anybody ever used motor oil to lube their chain??
Old May 14, 2007 | 08:41 PM
LSintegra's Avatar
Default Re: lubeing chain (02f4i600)
where or who did you hear that from?
Old May 14, 2007 | 08:50 PM
Johnny_Rocket's Avatar
Default Re: lubeing chain (LSintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSintegra &raquo;</TD></TR><TR><TD CLASS="quote">where or who did you hear that from?</TD></TR></TABLE>
x2
Old May 14, 2007 | 08:58 PM
LSintegra's Avatar
i think if you do that, it will be really messy
Old May 14, 2007 | 09:17 PM
Jasper_db1's Avatar
Sure on a non o-ring chain 49cc 2-stroke pocketbike.
Old May 14, 2007 | 09:21 PM
just wondering. friend said you could but i had never seen it.
Old May 14, 2007 | 09:32 PM
LSintegra's Avatar
you should just stick to using the chain lube. also make sure you lube your chain every 500miles and get check if it needs tightening every 3k or so. if the chain gets too loose it will hurt your mpg and maybe do greater damage in the long run.
Old May 14, 2007 | 09:36 PM
marmaladedad's Avatar
I use WD40 to clean my chain, then whichever chain lube I: a) got fo' free! or b) can steal from my buddies.
Be sure you're not just spraying *****-nilly. Spraying the outside of the chain doesn't do jack.
Old May 14, 2007 | 10:16 PM
Jasper_db1's Avatar
Default Re: (marmaladeboy)
you must not use RK chains
Old May 14, 2007 | 11:49 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (Jasper_db1)
just get regular chain lube/wax. its like $6 a can.
Old May 14, 2007 | 11:55 PM
methos713's Avatar
I use dupont muli-purpose teflon lube to lube up my chain. Got it at lowes. Here's a link...
http://www.webbikeworld.com/t2...e.htm
Old May 15, 2007 | 04:11 AM
Eva01's Avatar
Default Re: (methos713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">I use dupont muli-purpose teflon lube to lube up my chain. Got it at lowes. Here's a link...
http://www.webbikeworld.com/t2...e.htm</TD></TR></TABLE>
I use the same stuff, work great and pretty dang cheap! BTW, don't use oil as it will damage your o-rings.
Old May 15, 2007 | 12:12 PM
warrenjrose's Avatar
I use gear oil... Looks like motor oil, definately smells bad. If you saw someone using "oil" it was probably gear oil.
Old May 15, 2007 | 11:12 PM
Squad1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jasper_db1 &raquo;</TD></TR><TR><TD CLASS="quote">you must not use RK chains </TD></TR></TABLE>
lol
Old May 16, 2007 | 09:55 PM
Matt Sterbator's Avatar
Default Re: (Squad1)
WD-40
Use it to clean and lube.
Old May 20, 2007 | 10:44 AM
Default Re: (Matt Sterbator)
any input on royal purple chain lube? guy at the parts counter at napa recommended it to me. This is my first bike so any tips on lubeing the chain would also be appreciated. I'm taking it to our local Honda motorcycle dealership for maintenance but i want to get all this stuff down so i can do it on my own.
Old May 20, 2007 | 11:25 AM
slm's Avatar
slm
Default Re: (02hondaf4i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02hondaf4i &raquo;</TD></TR><TR><TD CLASS="quote">any input on royal purple chain lube? guy at the parts counter at napa recommended it to me. This is my first bike so any tips on lubeing the chain would also be appreciated. I'm taking it to our local Honda motorcycle dealership for maintenance but i want to get all this stuff down so i can do it on my own.</TD></TR></TABLE>
Is it okay for an O ring chain? If it is, you could use it. Personally, once my can of Bel-ray runs out, I'll be running the dupont lube in the link. 6.50 for a 6 ounce can of bel- ray or 6.95 for an 11 ounce? No contest. Clean the chain with a rag and kerosene, maybe take for quick ride to warm it up (I use a hair dryer) and spray the lube on the side of the chain that contacts the sprokets.
Old May 20, 2007 | 11:41 AM
85's Avatar
85
DO NOT USE MOTOR OIL OR GEAR OIL!
i fried a chain some time back after about 300miles of cleaning and re-oiling it. it was literally smoking! what happened was, i cleaned it and used some off the shelf oil that wasn't stickey so it all fell off until the chain was dry. chain lube is sticky for a reason!
BJA86
Audio / Security / Video
23
Nov 11, 2007 04:01 PM
Bulli Kid
41
Aug 24, 2007 06:36 PM
B16b-EJ8
13
Apr 24, 2007 03:57 PM
jowy
Mar 3, 2005 11:09 PM
Elvis1977
Nov 11, 2003 09:02 AM
