Type SH Engine Removal
you sure can... i'm about to pull mine out again. all you gotta do is make sure all hoses and wires are disconnected, and then obviously the axles and mounts are all removed... as well as the exhaust. just lift slowly, so that if you did miss anything, you can remove it, instead of breaking it.
good luck.
good luck.
89DXDann
May 27, 2004 10:24 PM
