Guys. I need Help lol (Spoon X-Brace)
I have a spoon X-brace just sitting in my trunk right now, but heres my question.
I don't have any of the 4 bolts for the X-brace. Does the Spoon X-Brace utilize the stock 4 pt bolts that is on the car as is? Or do I need to buy seperate bolts? My buddies JIC came with 4 bolts, but im hearing differnet stories that I can use my stock OE's? blah. Thanks fellers
IIRC, the ends of your Spoon Xbrace shouldn't need much of a longer bolt. I'm sure the stock ones will fit; they bolt into stock bracing points.
In comparison, my Muz brace came with hex-key bolts, and were about 1/4" longer than stock bolts.
Modified by Mr. Projekt at 9:26 PM 5/14/2007
im not sure but you under and find out... remove the 14mm bolt and see if it fits the x brace hole and if you have more thread left...
some brace are thicker than others, therefore, it needs longer bolts...
similar to spoon but thicker..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouSo »</TD></TR><TR><TD CLASS="quote">So aftermarket bolts then it is?</TD></TR></TABLE>
read... dont just look at the picture.. rofl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt »</TD></TR><TR><TD CLASS="quote">^^^ The ends of that bar looks like the ones on my brace. I editted my post. The Spoon brace's ends aren't flat.
no its not...
the comtech one are flat in one side..
go edit again
</TD></TR></TABLE>no its not...
go edit again
YGPMMFB!
YGPMMFB!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk »</TD></TR><TR><TD CLASS="quote">
read... dont just look at the picture.. rofl</TD></TR></TABLE>
hahaha! Thanks dudes. Dang's got some exta bolts from me, so we'll see from there
