Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Vibrating pedals-clu
Old May 14, 2007 | 12:24 PM
jivi's Avatar
Default Vibrating pedals-clutch and accelarator
You guys experienced this problem? all engine mounts are new.
Old May 18, 2007 | 07:23 PM
civ_nate's Avatar
Default Re: Vibrating pedals-clutch and accelarator (jivi)
yep i get that too, i have 80xxxkm on the car/engine and subframe/mounts are perfectly tight.... its just a slight minor vibrating.... enough that its anoying...
Old May 18, 2007 | 08:22 PM
portaman03's Avatar
Default Re: Vibrating pedals-clutch and accelarator (civ_nate)
Do either of you guys have after market wheels? Just a guess.
Old May 18, 2007 | 08:33 PM
jivi's Avatar
Default Re: Vibrating pedals-clutch and accelarator (portaman03)
yes I have, so youre saying that misaligned wheels can lead to this problem.Probably you're right since i changed my engine I did'nt go for wheel alignment where the mechanics remove that knuckle arms when they do the repair.
anyways i will go to fastrack and go for alignment, post any improvement here. Thanks.
Old May 18, 2007 | 10:15 PM
portaman03's Avatar
If you have aftermarket wheels, you may need to have hub-centric rings (if you dont already have them).
I was implying that your wheels may be lug-centric, which would cause vibration.
Not sure if the vibration would be felt in the pedals though, does the car in general shake?
Old May 19, 2007 | 11:21 AM
i-VTEC_DOHC's Avatar
hmm it wont deal with the wheels cuz it would vibrate the steering wheel... but hmm.. thats weird though.. but hey thats what the honda dealer is for =]
Old May 19, 2007 | 06:40 PM
jimmycash's Avatar
if your steering wheel vibrates it your front tires or excessive rotor run out
if your pelals vibrate its your rear tires or out of round drums or excessives rotor run out. if your over torque your lugges you can get vibration too and low tire preessure
Old May 20, 2007 | 07:40 AM
03EM2guy's Avatar
Default Re: Vibrating pedals-clutch and accelarator (jimmycash)
that was happening to me so i got my rims re-balanced and now im fine
msinsky14
49
Jan 27, 2011 08:10 AM
cocoluco
Suspension & Brakes
11
Mar 11, 2009 10:03 PM
SpeedoKing
10
Jul 13, 2007 06:53 PM
ComposiMo
Sep 1, 2004 02:29 PM
jdmstreethatch
Jan 11, 2004 04:28 PM
