stripped screw
Old May 14, 2007 | 11:51 AM
shifts's Avatar
Default stripped screw
need some suggestions. i have cel 10 for iat n one of the screws is stripped. ive tried grippin it w/vice grips but no success. REALLY dont want to take off the intake mani since its a pain. drill wont fit else id use that.
Old May 14, 2007 | 12:09 PM
joebowlr321's Avatar
Default Re: stripped screw (shifts)
take off the mani....going to save u alot of headaches and time.....they aren't a pain...u can rip one off with coolant lines an all in under 15 mins....or is that just me...
Old May 14, 2007 | 01:19 PM
ndogg's Avatar
Default Re: stripped screw (joebowlr321)
ya 15 minutes until you have to scrape the old gasket off... that takes days... you could cut the head off and when you get your iat off there would be more screw to get a grip w/ vice grips?
edit: how about cutting a notch in the screw and using a huge *** flathead?
Old May 14, 2007 | 02:58 PM
shifts's Avatar
Default Re: stripped screw (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">ya 15 minutes until you have to scrape the old gasket off... that takes days... you could cut the head off and when you get your iat off there would be more screw to get a grip w/ vice grips?
edit: how about cutting a notch in the screw and using a huge *** flathead?</TD></TR></TABLE>
yeah the nuts under the mani r the hard part. n ive thought bout cutting the head off. might try it this weekend. what would i cut a notch w/?
Old May 14, 2007 | 03:40 PM
ndogg's Avatar
dremel w/ cutoff wheel?
Old May 14, 2007 | 03:44 PM
shifts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">dremel w/ cutoff wheel?</TD></TR></TABLE>
no dremel only a drill with the cutoff wheel bit. .
Old May 15, 2007 | 12:33 PM
shifts's Avatar
ne1 else?
Old May 16, 2007 | 09:00 PM
shifts's Avatar
other suggestions before i take the head off the screw?
Old May 22, 2007 | 07:24 PM
89db15's Avatar
try using an impact chizel. thats what i did when i had a stripped screw. u cab get some pretty long bits
akamrmike
May 1, 2009 09:39 AM
Sprockets
Nov 30, 2007 10:37 AM
prodragEG
Nov 5, 2007 08:23 AM
Reelizmpro
Feb 21, 2006 10:13 AM
kinvid22
Jul 13, 2004 11:14 PM
