-6an to 14mm x 1.5 adapter for GT coolant fitting questions
I have banjo fittings, but I'd rather use -6an to 14mm x 1.5 adapters. I also want to use either aluminum or stainless steel. I've seen the fitting that ATP sells, but it looks like regular zinc coated steel.
If I buy these fittings from Earls, Russell, etc., they don't come with the o-ring. Could someone tell me what kind of o-ring will seal properly. Thanks for the help.
I just used a cush washer type copper gasket between the fitting and turbo...a -6 AN fitting was then used.....no leaks and looks great IMO....hopefully it answers ur quest...
You can kinda see the copper gasket to help seal the fittings.......
Re: (DA_HONDA_BOY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_HONDA_BOY »</TD></TR><TR><TD CLASS="quote">summitracing.com starting at $2.25 thay have aluminum</TD></TR></TABLE>
Thanks, but I know where to get them. I just want to know if it's safe to use aluminum, because I've only seen these adapters in steel.
I used honda oil drain bolt crush washers ( dont know if there's differences, but the ones for the D17/Kseries motors) under Earls fittings.... No leaks thus far in a year and a half.
Re: (PrecisionH23a)
the fitting your looking for is made by adapt all, my local aeroquip fitting reseller (moreland hose in NY) sells them to me for 5$ each. Atp has them here for more but they are very very nice.
http://www.atpturbo.com/Mercha...-FTG1
Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">You can also use a stat-o-seal.</TD></TR></TABLE>
stat-o-seal, FTW! I was hoping someone would suggest this type. I saw this type in the Goodridge catalog.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdsGTI »</TD></TR><TR><TD CLASS="quote">the fitting your looking for is made by adapt all, my local aeroquip fitting reseller (moreland hose in NY) sells them to me for 5$ each. Atp has them here for more but they are very very nice.</TD></TR></TABLE>
Thanks EdsGTI, that's the ATP fitting I was talking about. Unfortunately, it's "regular" steel. I think an aluminum Aeroquip fitting would be nicer, IMO.
nowtype
04-25-2010 07:04 PM
msmotorsports
01-12-2005 08:25 AM
