HELP having speedo problems
hey everyone,
just finished a b18c swap into a 95 civic which was originally an automatic
now the first drive i took it for the speedo wasnt working and it through code 17 now i have 2 different vss around so i put the orignal electrical part in and it showed the speed but it was jumping and now nothing....all fuses are good
what should i do guys/gals???
thanks
M
thanks
M
i check both ends of the plug and they are rust/corrosion free....
i also made sure the contacts were good and no change
im not getting anything on the cluster now
i had this same problem with my b16... you checked it.. i changed mine out.. and make sure you are bolting it all the way in there.. thats the key!!!!! bolt all the way in.. they are long bolts
i just put the original auto ecu in and the speedo works perfectly fine but when i put the b18c p72 in i get no speedo
are the pins different for each ecu???
gwegcivic
21
Mar 3, 2009 12:33 AM
LukeDanger
Feb 23, 2004 04:09 AM
