i need help !!!!! my eg is on life support.
Old May 13, 2007 | 08:45 PM
hondaon18's's Avatar
Default my eg is on life support.
i need help i got a 92 honda eg, dx hatchback with some problems . first of all i cant get none of the interior lights, dash lights, turn signal lights or radio and brake lights to work . i replaced all the fuses i seen that were bad. also added fuses that were missing. okay now heres a dumb question the car has a sohc engine in it with a gsr ecu. can that be the problem maybe because that ecu aint for the eg. also if this can give you guys any ideas the first fuse thats in the fuse block located buy the battery is burnt the number 50 watt one. can that be the problem . because i know i need to replace it. or are thier any relays that i should be looking for so i can solve this problem . the second problem that i need help with is i cant get the trunk to open for nothing. the person that i bought it from cut the wire . i don't know why he just did. but i tried to pull the remaining wire that was left but nothing would pop or open. now here where i want to know if thier is any way i can remove the plactic cover thats on the trunk and try to manually open it or is thier any another way because not even the key wont do nothing to open it. so you guys see why my eg is on life support . and please any ideas that you guys have will not be turned down or looked away. i need all the help i can get. thanks
Modified by hondaon18's at 12:25 PM 5/14/2007
LoGaN-VanG
23
Jun 20, 2009 08:32 PM
93gunner
Jun 4, 2007 12:40 PM
airmax
11
Sep 18, 2006 06:17 PM
allmotaeg6
Dec 13, 2003 07:21 AM
