crx wreaks of gas
Old May 13, 2007 | 06:16 PM
ryyo's Avatar
Default crx wreaks of gas
I've got an '88 crx with a zc swap that just wreaks of gasoline when driven. I was told that I might want to try replacing the o2 sensor, but the guy that I bought it from said that it was recently replaced. I've also been told that zc's have the tendancy to run rich. Any other suggestions of other things that I should check out would be greatly appreciated.
Thanks
Ryan
Old May 13, 2007 | 06:38 PM
Crx Jimmy's Avatar
Default Re: crx wreaks of gas (ryyo)
Are you sure you dont have a leak?
Old May 13, 2007 | 08:01 PM
ryyo's Avatar
Default Re: crx wreaks of gas (Crx Jimmy)
I might, but I am a NOOB and aren't quite sure where to look for the leaks at
Old May 13, 2007 | 08:07 PM
DenzComp's Avatar
Start it up over a dry surface...Let it run and check for drips
Old May 14, 2007 | 04:28 AM
mikejr83's Avatar
Take out the cargo bay area and look around where the fuel pump goes in. You may have a leak there. This area would cause you to smell it real bad. Also check on the filter that is on the firewall. If anyone messed with those fittings then your crush washers may be causing it to leak.
Old May 14, 2007 | 04:27 PM
ryyo's Avatar
It's not leaking under the car, and I don't belive there's a leak near the fuel pump (because I have all that open so I can see it on a daily basis). I will need to check that filter on the firewall though. Is it just a matter of replacing the crush washers if that's the problem?
Old May 14, 2007 | 05:33 PM
KevinT707's Avatar
One of the fuel lines on the driver's side next to the fuel tank on my CRX was also leaking from rubbing against something but I would smell gas for 6-12 months till I ever saw it leak onto the ground so .. check the fuel lines under the car near the tank!
Old May 14, 2007 | 05:45 PM
linx's Avatar
if it is not your gas tank or your exhaust. There is a vent line in the engine compartment that goes into the passenger side fender try checking that it did not come off.
Old May 14, 2007 | 06:37 PM
hybridmiklo's Avatar
Default Re: crx wreaks of gas (linx)
Fill up the car with gas, drive a few miles and check for gas leaking out around the gas tank. Also check the fuel lines from the firewall to the motor. Touch them with your hands and check for wetness.
Old May 14, 2007 | 06:39 PM
wiZCo's Avatar
Stouts 'n' Scotch
Yeah, if it's a bad gas smell, you're leaking gas, not just simply running rich. The ZC should not run rich if you're running the correct ECU.
Old May 14, 2007 | 10:26 PM
boosted timebomb's Avatar
just crawl around under the car with a propane torch when it catches on fire you found your leak.......THAT WAS A JOKE PLEASE DONT DO THAT
Old May 15, 2007 | 07:25 AM
CRX Toad's Avatar
It may also be the rubber connection between the filler and the tank. On these cars at the age they are this connection starts to deteriorate and you get a strong gas smell. Thing that sucks is they are behind the interior panels so replacement isn't always easy.
Old May 15, 2007 | 08:48 AM
Fobtions's Avatar
Default Re: (CRX Toad)
i had this problem when my injector seals were bad. check those
Old May 15, 2007 | 09:39 AM
harmonator84's Avatar
Default Re: (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">i had this problem when my injector seals were bad. check those</TD></TR></TABLE>
damn you beat me to it...I had this SAME problem...after checking everything out it was the Orings on my injectors...easy and cheap fix..havent had any problems yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted timebomb &raquo;</TD></TR><TR><TD CLASS="quote">just crawl around under the car with a propane torch when it catches on fire you found your leak.......THAT WAS A JOKE PLEASE DONT DO THAT </TD></TR></TABLE>
Haha...i am glad you told him you were JK though...he would have prob tried it.
Old May 15, 2007 | 09:52 AM
mar778c's Avatar
Community Builder
Community Influencer
X3 agreed
Old May 15, 2007 | 04:03 PM
mikejr83's Avatar
Default Re: (harmonator84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 &raquo;</TD></TR><TR><TD CLASS="quote">
Haha...i am glad you told him you were JK though...he would have prob tried it.</TD></TR></TABLE>
Had this problem as well as connections on the filter and from the filter to the fuel rail. The only time I smelled it while driving was on the connections on the filter. It leaked down the firewall and made it into the area where the harness passes through.
Hope you figure it out though!
Old May 15, 2007 | 04:19 PM
Default Re: (mikejr83)
now that i think about it check the hose coming off the fpr maybe it got overtightened. i had this problem and i just got a new hose and clamp and it was fine
BigbamaBen
Sep 2, 2011 07:54 AM
munchlax
Feb 21, 2011 11:49 AM
C-rexproject
Apr 11, 2007 05:02 PM
Xander teh Grate!
Jan 14, 2006 03:02 PM
Sanj
Sep 10, 2005 07:52 PM
