i need help with my 89 crx
My Crx wont start it isn't getting any fuel and i cant figure it out? But there is a small leake in the gas tank will this make a difference (i made sure there was gas in it before i tryed to start it. Any ideas
Re: i need help with my 89 crx (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec »</TD></TR><TR><TD CLASS="quote">I'd say fix the leak first ...it may be a vacuum thing that the gas ain't getting to your motor... </TD></TR></TABLE>
Re: i need help with my 89 crx (C-rexproject)
two obvious culprits could be the main relay or a clogged filter. a clogged filter is easy to check. turn the ignition on and crack the banjo bolt on the line coming from the tank to see if there is fuel. if there is none then your pump is not working, usually either because of a bad pump or no juice from the main relay. vacuum controls are only for the pressure regulator if i am not mistaken. be careful around spraying fuel obviously.
shawnperolis
08-20-2010 06:49 PM
davechuck
03-18-2004 04:10 PM
Kimo
07-06-2003 07:51 PM
