Funny smell coming out of vents.
Old May 13, 2007 | 05:40 PM
Red_ED8's Avatar
Default Funny smell coming out of vents.
Well I'm not sure but I think something is dead in either the blower assy or the vent some where. Does anyone know how I can clean out the blower? Sea Foam or something? And what do I have to worry about messing up, so I don't break something when I try to clean it. Thanks for any info.
Old May 13, 2007 | 05:51 PM
doublethink's Avatar
Default Re: Funny smell coming out of vents. (Blue_DX)
like dead animal?
i really dont think any mammal is small enough to fit through the vents......
this last crx i bought had a smelly vent system, what i did was bought some:
"ANTIMICROBORAL" Febreze Spray
1) you turn on the vent with both upper and lower open, to the highest speed.
2) set the temp to fully cold
3) make sure its set to pull air from outside the car, not the loopback setting.
then go outside the car, and spray into the input ducts at the base of windshield.
what will happen is the car will suck the febreze into the vent system via those ducts and hopefully help you.
if something is actually physically dead in there then get a Helms manual and pull that dash etc.....
Old May 13, 2007 | 05:55 PM
ludesrv's Avatar
Full heat, level 4, air fresheners inside the vents...seal the interior (make the fan suck cabin air not exterior air) and leave it for a few hours.
It's just the smell of old (or dead stuff). If it doesn't go away by covering it up, then pull your dash out (simple, I do them in 20-25 minutes now) and clean each vent one by one.
Old May 13, 2007 | 05:57 PM
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Full heat, level 4, air fresheners inside the vents...seal the interior (make the fan suck cabin air not exterior air) and leave it for a few hours.
It's just the smell of old (or dead stuff). If it doesn't go away by covering it up, then pull your dash out (simple, I do them in 20-25 minutes now) and clean each vent one by one.</TD></TR></TABLE>
what if the problem is on the way into the car?
Old May 13, 2007 | 06:00 PM
ludesrv's Avatar
Default Re: (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">
what if the problem is on the way into the car?</TD></TR></TABLE>
Ummm then you pull your dash and you clean each piece one by one...once you pull the dash you will see the blower assembly is just a few more nuts and bolts.
Old May 13, 2007 | 06:06 PM
Red_ED8's Avatar
So is there a way to clean out the blower? I have all ready stripped out all the interior (- dash) to clean it because the previous owner was a smoker. So If I need to take out the blower or vents, this is the time to do it.
Old May 13, 2007 | 06:11 PM
Iron_Forrix's Avatar
yea, the blower is easy to take out and clean. jsut get under there and take out the blower and the black box attached to it (i forgot the name oif it). make sure theres no freeon or coolant in your ac system. those run to the black box next to the blower. you need to disconnect them.
heres what i found in my old crx that was causing a loud whirring noise and cause a "funny" smell
so get to dissassembling and scrubbing!
Old May 13, 2007 | 06:45 PM
Crx Jimmy's Avatar
Default Re: (Iron_Forrix)
DAMN!! looks like something Satan created
Old May 13, 2007 | 10:54 PM
EFM_ookie's Avatar
Default Re: (Crx Jimmy)
thats so ****** nasty LOL
Old May 14, 2007 | 04:34 AM
janz3n's Avatar
Default Re: (89_Mangina_SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue_DX &raquo;</TD></TR><TR><TD CLASS="quote">Sea Foam or something? </TD></TR></TABLE>
lol. thats ******* funny.
Old May 14, 2007 | 06:26 AM
K2e2vin's Avatar
It could just be mold/mildew. My Accord had that problem, I just spray Lysol down the vent and took off the wiper cowl; sprayed some in the vent from there, and the smell never came back.
btw, I tried Fabreeze, etc. too, but the smell kept coming back. Lysol did the trick.
Old May 14, 2007 | 07:11 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">DAMN!! looks like something Satan created
</TD></TR></TABLE> bwhahaha...@ my dad's work a lot of people would come in like every other month with a electrical problem and it was always those bastards getting in there and chewing it up...we always saved it for the customer because they never believed it. It was really nasty because some would like sleep neat the manifold and other heat outputs, and they would be all crispy
Old May 14, 2007 | 07:50 AM
Default Re: (89efDUSTY)
lol, yea that little leather dried bastard was the culprit behind why my car didnt run. He chewed the injector wires and the wires to the fuel pump. too bad it took me a couple months to find him afterwards
Old May 15, 2007 | 09:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iron_Forrix &raquo;</TD></TR><TR><TD CLASS="quote">
thats the most insane thing ive ever seen on this forum.
Old May 15, 2007 | 09:16 PM
STREETWERKZ's Avatar
rat mummy. lovely.
Old May 16, 2007 | 02:47 AM
jchrm80's Avatar
if its a horrible burning smell it could be your blower motor going up. mine did and the smell was outstanding.
Old May 16, 2007 | 05:33 AM
abnaasefmb's Avatar
Default Re: (jchrm80)
Yeah I was going to say that mice and little animals can defiantly get in there but it looks like I was beat to it. Never leave food in your car. I once head about a lady that had a bowl of like 2lbs of heresy kisses in her car, she parked it and the next day there were gone. When she turned on the heater little tin foils started blowing out the vents. Apparently mice had taken all the kisses and hide them in the air ducts.
Old May 16, 2007 | 05:41 AM
daoshao's Avatar
damn, a mummified rat...
Old May 16, 2007 | 07:49 AM
crxma22's Avatar
Default Re: (daoshao)
winner!!! winner!!!! winner!!!! hot damn that's nasty.... then you picked it up with no gloves??? that thing looks like it got scrabbies hahahaha
Old May 16, 2007 | 10:37 AM
BIG_T's Avatar
Default Re: (crxma22)
lol i have the same lil noise looks like im in for a surprise
Old May 16, 2007 | 11:38 AM
Bob_760's Avatar
Default Re: (BIG_T)
Note to self: pull out blower and check for disgusting things so as not to have to worry about them later...
Old May 16, 2007 | 11:55 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
That reminds me of this:
Old May 16, 2007 | 12:51 PM
No2Pencil's Avatar
LOL it couldent handle VTAK
Old May 16, 2007 | 02:41 PM
harmonator84's Avatar
Default Re: (No2Pencil)
I remember Iron_Forrix posting that before....looks like he beat me to posting the pics though.
Nonio
Sep 24, 2010 03:10 AM
dmurphy2k3
May 15, 2005 04:01 PM
skrewdriver88
23
Aug 30, 2004 09:59 PM
JDM_Type-R
Sep 12, 2003 02:47 AM
RSZero1
Feb 24, 2003 08:15 AM
