4 way disc swap
Old May 13, 2007 | 02:35 PM
isl_cruiser's Avatar
Default 4 way disc swap
im just wondering what i need to completly do a rear disc swap on my crx.
Old May 13, 2007 | 03:10 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: 4 way disc swap (isl_cruiser)
The swap has been covered many times in other threads, just run a search.
In my experience, not worth the time and money, nothing will be gained except weight.
Old May 13, 2007 | 03:24 PM
Crx Jimmy's Avatar
Default Re: 4 way disc swap (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">The swap has been covered many times in other threads, just run a search.
In my experience, not worth the time and money, nothing will be gained except weight.</TD></TR></TABLE>
this is correct, but if you are dead set on it, you need the complete front spindles from a ex/da, and complete trailing arms from a da, dc, eg . you will need to buy new rubber or ss brake lines if they are not included and you will probably wan to buy new pads/rotors as well
Old May 13, 2007 | 06:23 PM
ryyo's Avatar
Default Re: 4 way disc swap (Crx Jimmy)
yeah, I went for a ride in my friend's crx last night with the disc conversion, and it was okay but I told him I probably wouldn't spend the money on it.
Old May 14, 2007 | 09:49 AM
Default Re: 4 way disc swap (ryyo)
right on. im not gonna both with it, with that feedback...Thanx guys
Peace
Old May 14, 2007 | 09:51 AM
EL Vap133's Avatar
All you need to know is right here: https://honda-tech.com/zerothread/1508680
Old May 14, 2007 | 10:08 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by isl_cruiser &raquo;</TD></TR><TR><TD CLASS="quote">im just wondering what i need to completly do a rear disc swap on my crx.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
you need the complete front spindles from a ex/da, </TD></TR></TABLE> did i read something wrong...isnt he just looking for the rears??? But if you can find them used, they are worth the money, for me $80 also a little more weight in the rear is ok compared to the front for this car. It is actually quite a difference on my DX but i also upgraded the prop valve, BB, and MC...that all cost me about 50...so in all it was 130 well spent on my part, but still most of the braking power is up front, and brembo blanks with a little better pads will do a lot...i just installed mine gl and make sure to search
Old May 14, 2007 | 05:43 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: 4 way disc swap (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote"> did i read something wrong...isnt he just looking for the rears??? But if you can find them used, they are worth the money, for me $80 also a little more weight in the rear is ok compared to the front for this car. It is actually quite a difference on my DX but i also upgraded the prop valve, BB, and MC...that all cost me about 50...so in all it was 130 well spent on my part, but still most of the braking power is up front, and brembo blanks with a little better pads will do a lot...i just installed mine gl and make sure to search </TD></TR></TABLE>
I would agree that adding the upgraded the prop valve, BB, and MC made a difference, but it not from the rear disk part of it.
In car reviews written when the 1990 CRX Si came out, it actually took 3 feet further to stop from 60 mph. I was old enough to drive when EF's were new on the lot, and i still have the original write ups on them.
shackler
Mar 1, 2007 08:37 AM
scarface50370
Dec 4, 2005 03:58 PM
bdicustoms
10
Aug 1, 2004 10:13 AM
LostCRX
Mar 24, 2004 10:54 AM
aVstAr
12
Nov 30, 2003 05:59 PM
