integra brake swap
Old 07-31-2004, 07:52 PM
Default integra brake swap
i want to do a integra brake swap on my eg but i need to know EVERYTHING that i need to find used or buy new to complete this swap, including the MC and prop valve. can anyone help me out on what i need. thanks
bdicustoms is offline
Old 07-31-2004, 09:01 PM
honda9369's Avatar
Default Re: integra brake swap (bdicustoms)
honda9369 is offline
Old 07-31-2004, 10:24 PM
SpydiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdicustoms &raquo;</TD></TR><TR><TD CLASS="quote">i want to do a integra brake swap on my eg but i need to know EVERYTHING that i need to find used or buy new to complete this swap, including the MC and prop valve. can anyone help me out on what i need. thanks</TD></TR></TABLE>
Front? Rear? All the way around? Be more specific
SpydiR is offline
Old 07-31-2004, 10:25 PM
honda9369's Avatar
Default Re: integra brake swap (SpydiR)
rear
Old 07-31-2004, 10:27 PM
buckNasty's Avatar
Default Re: integra brake swap (honda9369)
i think its rear lca's, rotors, calipers, pads, brake lines, ebrake cables, prop valve, id personally upgrade my mc and booster also.
buckNasty is offline
Old 08-01-2004, 06:39 AM
Default Re: integra brake swap (bucbaby)
front and back, everything that i need to do the swap.
Old 08-01-2004, 07:36 AM
bump
Old 08-01-2004, 08:23 AM
can someone help me out???
Old 08-01-2004, 08:37 AM
cxSHOE's Avatar
are you going to be using an integra booster or a civic booster? if your going to be using an integra booster i have a 1" m/c for you.
cxSHOE is offline
Old 08-01-2004, 09:58 AM
elwood's Avatar
Rear:
Trailing arm assembly(callipers, rotors, rear trailing arm, and a ton of little things. Just ask for the rear trailing arm assembly at the junk yard.)
Flexable brake line with the banjo bolt.(most people cut them, and they are about $50 a side from honda, or $25 for off brand Shmuks ones.)
Rear Options:
New control arms with swaybar mounts
Rear swaybar
Endlinks
Front:
Front Knuckle (again, just ask. Rotor, caliber, brake lines, all that good stuff.)
Front Options:
Control arms
Front swaybar
Endlinks
elwood is offline
Old 08-01-2004, 10:13 AM
fakemike's Avatar
Default Re: integra brake swap (elwood)
You can get a 91 civic ex four door MC. It bolts right to EGs without bending the brake lines. It works with the stock EG prop valve. Its a 15/16" MC. It works well with Integra brake swaps on civics. Cost ~$60(with core) at local auto parts stores.
A lot of people around h-t have this on their EGs.
fakemike is offline
ekcivicdreams
15
08-13-2014 07:42 AM
SCIVIC94
11-25-2007 10:27 PM
Seanith
02-22-2004 09:56 AM
joeski
09-23-2003 11:32 AM
1SpoolnH
12
08-14-2003 11:33 AM
Quick Reply: integra brake swap
  • Ask a Question
Question Title:
Description:
