b-series trannys
Old May 13, 2007 | 02:28 PM
jfrase06's Avatar
Default b-series trannys
will any b-series tranny fit on a b18b?!?!?!? not sure if this was covered if it was srry to have posted............but thanks for the help!
Old May 13, 2007 | 02:35 PM
vlc92189's Avatar
Default Re: b-series trannys (jfrase06)
if its a hydraulic tranny then yes.
Old May 14, 2007 | 07:48 AM
Twistd_Cody's Avatar
Default Re: b-series trannys (vlc92189)
which is the best tranny for b16a ... a b16 , ls , or the gsr tranny??
thanks.
Old May 14, 2007 | 07:49 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: b-series trannys (Twistd_Cody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Twistd_Cody &raquo;</TD></TR><TR><TD CLASS="quote">which is the best tranny for b16a ... a b16 , ls , or the gsr tranny??
thanks.</TD></TR></TABLE>
Depends on what you want.
The ls is definately not an option for go-fast-ness.
b16 or gsr.
b16 has the shortest gearing.
Old May 14, 2007 | 07:55 AM
Default Re: b-series trannys (ek forever guy)
well i just did the swap and it supposedly has the ls tranny on it but the code on the tranny is not there but i was gonna go with the gsr is there another way to find the tranny code....
Old May 14, 2007 | 08:36 AM
Ek Forever y0!
Unless it's ground off it should be stamped into the tranny.
Old May 14, 2007 | 09:18 AM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Unless it's ground off it should be stamped into the tranny.</TD></TR></TABLE>
Some just have stickers that start to come off after a good washing. I know my Y21 has only a sticker saying its a y21#########
Only stamp is the LSD baby.
Old May 14, 2007 | 10:01 AM
Pound4Pound's Avatar
Default Re: b-series trannys (sauceja)
LS has long gear ratios, so its only ideal for a daily driver or boost..
B16 has the shortest gear ratios, more ideal of racing a NA application
Old May 14, 2007 | 10:07 AM
93eg2james's Avatar
Yeah, that sticker with the bar code came off my tranny when i cleaned it. and theres no vin on the tranny.
Any other markings on the trans?
OP: Pretty much any 94-01 integra trans will work. Depending on what your plans are for the future; you should base your purchase on them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pound4Pound &raquo;</TD></TR><TR><TD CLASS="quote">LS has long gear ratios, so its only ideal for a daily driver or boost..
B16 has the shortest gear ratios, more ideal of racing a NA application</TD></TR></TABLE>
^^basic idea
Old May 14, 2007 | 01:29 PM
sauceja's Avatar
Default Re: b-series trannys (93eg2james)
Since there is a thread on tranny's
Will an automatic B series tranny swap easily into a 99 civic?
Buddy just trashed his auto D turbo. Idiot.
Anyway he has a B18 head and is going to buy my B16 block and wants to keep it auto for his girl.
Anyway off to use the search button but if anyone has some readily available links I am all for doing some reading.
Old May 14, 2007 | 03:29 PM
civicsi401's Avatar
yea i agree my b16a2 tranny works wonders at the track my friend had the gsr trany kinda suxed on take off and the ls is good for highway or top speed not good for drag or really hard launches
Old May 14, 2007 | 03:42 PM
Ek Forever y0!
Default Re: b-series trannys (civicsi401)
Are you kidding me!!! LS is good for daily, I agree. But it's terrible for any performance aspect.
Who in their right mind would put an LS trnny in for performance!!!
Old May 14, 2007 | 04:44 PM
95DxSi-R2
Guest
Posts: n/a
i had a gsr tranny and when i would shift @7800k i would fall out of vtec (500rpms)
now i have a itr tranny, same as a b16 gearing. now when i shift i stay in vtec.
i like it alot more.
Old May 17, 2007 | 09:00 PM
civicsi401's Avatar
Default Re: b-series trannys (95DxSi-R2)
woot just orderd a b16 motor tranny swap for a friend came with hydro tranny. my friends integra has cable so he told me he would give me the hydro tranny to do the swap i got it home come to find out it also has lsd in it and carbon synchros!!!! not bad for a couple hours work
fredsintegra
Jan 3, 2007 04:22 PM
baddog
Jan 24, 2005 06:18 PM
Kusai.Nihonjin.Desu
23
Mar 14, 2004 07:04 PM
92-EG6
30
Mar 14, 2004 06:18 AM
righteyeblind
Nov 21, 2003 03:15 PM
