Misfire Codes after Seafoam
Old May 13, 2007 | 01:19 PM
vinuneuro's Avatar
Default Misfire Codes after Seafoam
This is regarding a 98 Prelude. Many H22s experience a hesitation around 3k rpm due to carbon build-up in the egr port in the intake manifold. So, I ran half a can of seafoam through. The hesitation is gone now, but I'm getting misfire codes. Usually it's just on cyl1, sometimes cyl 1 and 3. Plugs have changed and valve adjustment has been done. Still having the problem. Any ideas?
Is it possible that the O2 sensor(s) got messed up and/or cat from all the carbon? Any other ideas?
Parts that are less than 10k miles old: Cap/rotor, plugs, wires, fuel filter, etc.
Old May 13, 2007 | 03:20 PM
arc_55's Avatar
Default Re: Misfire Codes after Seafoam (vinuneuro)
So i am assuming you have cleared these codes and they keep returning, correct?
Old May 13, 2007 | 03:31 PM
vinuneuro's Avatar
Default Re: Misfire Codes after Seafoam (arc_55)
Yes.
Old May 13, 2007 | 04:04 PM
joebowlr321's Avatar
Does the car stumble an have rough idle? or are the misfire codes just poping on and the vehicle running fine?
If ur car is running rough u might have a crack in ur cylinder head or valves
Old May 13, 2007 | 07:12 PM
PogKai's Avatar
change the spark plugs.
Kannan08
16
Oct 30, 2011 07:58 AM
EFstyle
11
May 3, 2010 06:02 PM
zanglezonker
Dec 9, 2008 04:17 AM
vinuneuro
Apr 18, 2007 02:41 PM
