b16 rebuild ???????????????????????????????????
bout 500-1500 depending on how thrifty you are
like if you go to autzone and just unload then your going to spend more but if you shop the net for gasket kits, and bearings for good prices and your block inst too mesed up you can get away for cheap, but on the other hand if you are rebuilding becuase you put 99 psi on your stock blocked b16a and it blew then its going to cost you
im in the same situation, i think im going to replace all the gaskets,seals maybe replace the rod bearings and main bearings, the water pump,t-belt,t-belt tentioner.
