D16z6 to D16Y7 swap. Need help.
Old May 12, 2007 | 09:35 PM
srg's Avatar
srg
Default D16z6 to D16Y7 swap. Need help.
Hello, I've blown my D16z6.. Now I bought D16Y7 engine and want to put it in my del sol.. I'd like to know what should I do with VTEC wires and ECU to make this engine work in my car..
Please help!
Old May 12, 2007 | 10:43 PM
EGmikeH22's Avatar
* B A N N E D *
there are many ways, but basically the ECU needs to talk to the VTEC solenoid.
so take a wire and run it from the VTEC solenoid through the firewall, and to the ECU where the pin is for VTEC (see charts stickeyed at the top of this forum)
Old May 12, 2007 | 10:47 PM
Luserkid's Avatar
Default Re: (EGmikeH22)
Y7 isnt a VTEC engine (unless you do a mini me) so forget about that.
If you have an obd1 year use the Z6 intake manifold and run a P05 (DX) ecu.
Old May 12, 2007 | 11:23 PM
srg's Avatar
srg
I had D16Z6 engine before, so all wires are for VTEC engine.. It's OBD2 year. Now I want to put D16Y7, I know it's not VTEC engine, so I'd like to know what should I do to VTEC wiring to make this engine work..? BTW, If I load D16Y7 bin into my D16Z6 ECU will that work?
Old May 12, 2007 | 11:30 PM
Luserkid's Avatar
Default Re: (srg)
So your converted to obd1 or are you still obd2?
Just leave the VTEC wiring hanging, its not going to hurt anything.
Old May 12, 2007 | 11:39 PM
srg's Avatar
srg
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">So your converted to obd1 or are you still obd2?</TD></TR></TABLE>
I'm still obd2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Just leave the VTEC wiring hanging, its not going to hurt anything. </TD></TR></TABLE>Are you shure it's not a problem? coz it's all I wanted to hear
Old May 13, 2007 | 12:37 AM
satinsol's Avatar
Default Re: (srg)
I dont think he meant literally leave it hanging but yea just run it back through the firewall and roll it up and tape it to somethin. You dont have to do anything with it other than not hook it up, because there is nothin to hook it to. And yea its no problem at all.
fatmexican
Feb 11, 2013 04:01 PM
94DCTeg
Dec 4, 2009 10:58 AM
blkroze4
May 30, 2007 06:51 AM
Slammd Sol
Mar 24, 2004 07:45 PM
