b16a obd1 motor to a obd2 motor....
Old May 12, 2007 | 08:21 PM
NOman0608's Avatar
Default b16a obd1 motor to a obd2 motor....
i have a 99 civic si,
i am putting in an obd1 b16a motor in it and was wanting to turn it into a obd2
what all do i really need to do?
Old May 12, 2007 | 08:35 PM
importfan0103's Avatar
Default Re: b16a obd1 motor to a obd2 motor.... (NOman0608)
do you have both complete engines and wiring harness first off,
i did this to my 00 si, the person i bought it off of didn;t take care of the engine and it died three months after i bought it. bought a jdm obd1 b16a and changed it over so it would pass inspection in mass( and so the obd2b ecu would work)
Old May 12, 2007 | 08:36 PM
what you want to do is swap all obd1 sensors that have different plugs then that of your obd2 wiring harness to the sensors from your obd2 b16a
Old May 12, 2007 | 08:39 PM
also you will need to add some sensors, for instance the crank positon sensor that is located by the crankshaft pully. you will want to use the obd2b wiring harness and make sure you have no unused plugs when finished in order to pass inspection
DetainedCivic
Apr 17, 2006 10:52 AM
tianporn
Dec 12, 2005 11:24 AM
mugenracer
Mar 3, 2005 05:19 PM
boostin4drcivic
Apr 30, 2004 11:40 AM
boot machine 5000
Mar 16, 2002 08:09 AM
