b16a jdm swap problems 1994 del sol
Old May 12, 2007 | 07:10 PM
ryan03's Avatar
Default b16a jdm swap problems 1994 del sol
alright guys i need alittle help
im in the proccess of finishing my swap of a b16a in a 1994 del sol
the problems i am having are.
oxy sensor says im running too rich and i can smell it.
the cluch seems to slip in 3rd and 4th at 4k havent noticed any other gears
this may also be due to the high rpm power loss and not the clutch
when vtec kicks in i almost fell that im losing alittle power but the noise from the intake increases alot. i actually have never herd a intake this loud!! and i cant say that its a good sound. it is louder than the exaust
i have checked the map and iacv and the oxy sensor seems to be fine.. i used it off my old d series
i have also used a map off the d series since osaka was kind enough to smash my throttle body!
there is good compression along all 4 cylinders
i am throwing a code for a tps sensor and i am in the proccess of getting a new one even though i do know this one worked fine on my old motor.
and another important question is that i seem to here a noise when letting off the clutch when not in gear it almost sounds like a slight friction noise.
when letting off the accelorator is seems as if i might be twisting the motor.. but it is installed correctly
so basically my problems are
running too rich killing power
clutch seems to act funky when stopped and in neutral
massive amount of intake noise while vtec is engaged
and motor seems alittle shaky in the engine bay
thanks for the help i know this is a big question..!
B16ahondadelsol
20
Jun 2, 2016 06:06 PM
jachrist
Feb 4, 2010 08:07 PM
92integra-R
Aug 17, 2008 06:20 AM
sick93sol
Jun 13, 2007 06:38 PM
jdm4dr
Dec 16, 2002 10:24 AM
