84mm vtec motors, whats your total timing???
Old May 12, 2007 | 06:30 PM
blackeg's Avatar
Default 84mm vtec motors, whats your total timing???
got some initial dyno time today and i noticed my graph (dont have it on me) is choppy above 6500rpms. i was adding timing and it was smoothing a little but i didnt want to push to far. currently im running between 17.5-18.25* at 10-11psi. my afrs are spot on in the low to mid 11s also.
Old May 12, 2007 | 06:51 PM
rsmotors's Avatar
I would run the afr around 11.8 instead. What compression are you running
Old May 12, 2007 | 08:22 PM
rdtech's Avatar
Default Re: 84mm vtec motors, whats your total timing??? (blackeg)
timing sound okay
what kind of fuel?
Old May 12, 2007 | 10:35 PM
sohc_turd's Avatar
Default Re: 84mm vtec motors, whats your total timing??? (rdtech)
Well, based soley off the info given, and generally speaking, If i had a 84mm bore i would probably start off with quite a bit more total timing and keep working up from there. I run 19.5* total timing on my little 75mm bore d16 at 10psi on pump gas, which is plenty safe on my setup.
84mm bore, the flame front is gonna have much more time to propagate.
I'm indirectly telling you that I would put more ignition in it. How much? untill it quites making power.
Old May 13, 2007 | 12:03 AM
building boost's Avatar
i am advanced 17 degrees on 14 psi.
Old May 13, 2007 | 12:07 AM
miller's Avatar
You really cant say what your timing should be, there are way way to many variables that will come into play when tuning that can change the outcome of timing settings.
Old May 13, 2007 | 06:25 AM
blackeg's Avatar
Default Re: 84mm vtec motors, whats your total timing??? (miller)
9.5 compression and 93 pump gas. i know you cant say exactly how much timing but i was just wondering if i was in the correct neighborhood with it. im very likely having other electrical problems because my car will loose power once or twice every 100 miles i drive it out of no where.
i wound up adding about 1-1.5* and it only made an additional 5 hp and 3 or 4tq so thats why i stopped. plugs show no detonation. im just kinda stumped
Old May 13, 2007 | 11:17 AM
Joseph Davis's Avatar
84mm ITR, .60 trim T04E compressor, 22 degrees at 26 psi on a straight diet of C16.
I was kind of surprised.
Using eCtune on a high-end 81mm build, whose timing numbers indicate "more advance" because you aren't tuning around the stock ECU code that adds a lot of hidden advance, 11.x psi at 26 degrees resulted in 345 whp on Torco 110. This is still somewhat relevant to the thread - it both indicates the difference between indicated and actual timing among available EMS, and as a previous poster responded bigger bore engines like more timing as the burn takes longer to cross the extra distance.
I have a pile of "precise" 84mm timing figures on my laptop, but typically I don't pay any attention. Things change around a LOT depending on bore/cam selection/cam timing deflection from being decked and milled/displacement/etc. For an 81-85mm B-series I typically go with a stock ignition map, add a .75-.9 deg/psi retard, and then adjust timing as needed based on plug/dyno feedback. If you look to this thread for the timing you need to run then you should do us all a favor and think seriously about a vasectomy before you breed.
Old May 13, 2007 | 12:53 PM
Jared's Avatar
Default Re: (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote"> If you look to this thread for the timing you need to run then you should do us all a favor and think seriously about a vasectomy before you breed. </TD></TR></TABLE>
Joe, you always know how to make me laugh.
Old May 13, 2007 | 04:46 PM
blackeg's Avatar
Default Re: (Jared)
too late, my wife is about to have our 5th!
im using uberdata, and the map that i dyno tuned last year as my basemap. main changes are 81 to 84mm and a blox im over an oem one.
alright heres one for you guys, it really seems to me im having an ignition or electrical power issue, my car was randomly loosing power and my oil press gauge is spiking all over. would having a wire for the gauge ground or touch something effect my ignition?
Old May 13, 2007 | 05:20 PM
sohc_turd's Avatar
Default Re: (blackeg)
sounds like a case of the gremlins, did you check all grounds?
Old May 13, 2007 | 06:06 PM
blackeg's Avatar
Default Re: (sohc_turd)
yeah grounds are all brand new and solid. the electrical issues didnt happen before i installed the turbo kit. and yeah, ive had the gremlins my whole life im just used to it
Old May 13, 2007 | 08:36 PM
Thanks, Jared, glad i can be of some use to someone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">too late, my wife is about to have our 5th!</TD></TR></TABLE>
Congrats!
Old May 14, 2007 | 02:06 AM
blackeg's Avatar
Congrats!</TD></TR></TABLE>
it was a joke with you saying i shouldnt reproduce. i dont have a wife or else i wouldnt have any money to **** away on my car. thank you for the advice in the thread i know youve been doing this a while
Old May 14, 2007 | 08:01 AM
96 GSR-T's Avatar
we were running 24 degrees on my boys 85mm LS/V with a T67 on it, car freaking loved it...
Old May 14, 2007 | 12:28 PM
blackeg's Avatar
Default Re: (96 GSR-T)
jeesuz!
im still on 93 pump and dont want to run that much tiiming...
Old May 14, 2007 | 01:52 PM
PrecisionH23a's Avatar
Joe... what did you mention before about having a mexican in the engine bay to spray fuel into the intake manifold and manually retard your dizzy?
Old May 14, 2007 | 02:41 PM
sohc_turd's Avatar
Default Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Joe... what did you mention before about having a mexican in the engine bay to spray fuel into the intake manifold and manually retard your dizzy?</TD></TR></TABLE>
LoL... was it Mexican or midget?
Old May 14, 2007 | 04:59 PM
It was a Puerto Rican midget named Rico. Well, in truth his name is Nelson but he tells everyone to call him Rico.
Here's his myspace: Rico
Feel free to harass him about it, he thought it was funny the first time.
Old May 15, 2007 | 04:58 AM
Ahhh... good old rico!
a1320honda
Engine Management and Tuning
May 9, 2013 11:28 AM
Dartanian
Feb 24, 2008 04:50 PM
Timmay
17
Jun 20, 2007 09:55 AM
spoolingb20
Apr 26, 2006 10:46 AM
SSBP DC2
Mar 2, 2003 10:47 PM
