Axle problems
Old May 12, 2007 | 04:42 PM
Kaspk's Avatar
Default Axle problems
I just got a new driver side axle with no ABS, I cant get the tranny part into the tranny...its going in, but an inch out still....any suggestions?
Old May 12, 2007 | 05:02 PM
dannis.'s Avatar
Default Re: Axle problems (Kaspk)
you sure you got it for your car?
Old May 12, 2007 | 05:09 PM
93baggedcivic's Avatar
put the old one up next tot he new one make sure its the right one
Old May 13, 2007 | 10:54 AM
Kaspk's Avatar
Default Re: Axle problems (93baggedcivic)
Yep its the same one, got it from advance discount auto parts
Old May 13, 2007 | 10:56 AM
Eran's Avatar
HT White Ops
Maybe I'm confused, but I didn't think axles had ABS ...
Old May 13, 2007 | 11:22 AM
bmoua's Avatar
try using a mallet to pound it in...usually i just keep working it until it goes in. make sure to check for leaks once your done.
Old May 13, 2007 | 11:25 AM
smiff95's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Maybe I'm confused, but I didn't think axles had ABS ...</TD></TR></TABLE>
Are you serious? (That ring around the outside of the hub... Looks kind of like a big synchro. If it does have ABS)
Kaspk, try harder you have to force the axel in. Some C clips are stronger than others, making it harder for the axel to go in.
Old May 13, 2007 | 11:26 AM
Eran's Avatar
HT White Ops
Default Re: (smiff95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smiff95 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm aware there are different axles ... I was just not aware your axles were what gave you ABS
( .... I was being sarcastic .... )
Old May 13, 2007 | 12:23 PM
Kaspk's Avatar
Should I use a 2x4 and mallet?
Old May 13, 2007 | 12:26 PM
Eran's Avatar
HT White Ops
Default Re: (Kaspk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kaspk &raquo;</TD></TR><TR><TD CLASS="quote">Should I use a 2x4 and mallet?</TD></TR></TABLE>
I usually use a deadblow and just smack it in.
Old May 13, 2007 | 01:27 PM
smiff95's Avatar
Default Re: (Eran)
I usually use a deadblow and just smack it in.</TD></TR></TABLE>
Get mad!
BLU CIVIC
Sep 11, 2009 11:06 AM
EG-SIXV-TEC
Dec 24, 2008 08:46 AM
SavEM1
Jul 27, 2006 02:00 PM
BB4
Mar 9, 2006 07:46 PM
xrtdac
Nov 7, 2003 10:27 AM
