Honda Oil cooler on a b18c1 block...have a few questions...
Old May 31, 2002 | 12:43 PM
Chubz's Avatar
Default Honda Oil cooler on a b18c1 block...have a few questions...
I just got my oil cooler from a good friend of mine. I obviously need the threaded extension for the filter, I ordered that from Acura. Is there anything else I need?
Old May 31, 2002 | 12:59 PM
SlapSmak's Avatar
Default Re: Honda Oil cooler on a b18c1 block...have a few questions... (SuperTech)
are you talking about the b18-c5 typr r oil cooler? if so, it does not circulate oil into an external oil cooling system, it actually uses the cool side of the radiator output to cool the casing around the oil flow extension plate. take a look at a haines manual and you will see what i am talking about.
Old May 31, 2002 | 01:02 PM
sgT's Avatar
sgT
you will need the water pipe from a 94-95 GSR or ITR and some hose
Old May 31, 2002 | 01:05 PM
reefer_bob's Avatar
Default Re: Honda Oil cooler on a b18c1 block...have a few questions... (sgT)
Is this really a worth while mod? What is the cool side temperature of the rad? What kind of delta-T can you get in the oil? I know cooler oil is always good, but how effective is this cooler?
Old May 31, 2002 | 01:22 PM
sgT's Avatar
sgT
Default Re: Honda Oil cooler on a b18c1 block...have a few questions... (reefer_bob)
I think its effective enough to warrant keeping it on the ITR.
Oil temp is always above water temp during high load situations so it must
help somewhat
Old May 31, 2002 | 02:06 PM
Beanman2k2's Avatar
yeah its just for now, it should help me some. I have the hoses for the oil cooler. Thanx for your help guys.
longshot
11
Jan 23, 2009 10:56 AM
Dan GSR
15
Feb 4, 2004 02:11 PM
90crxzc
Dec 6, 2003 01:36 PM
blykins
Jul 25, 2003 09:59 AM
TurBoXBirD16
Jul 9, 2002 09:45 AM
