Rear brake conversion - 00 Si to 00 EX
Old May 12, 2007 | 10:34 AM
Redz_EX's Avatar
Default Rear brake conversion - 00 Si to 00 EX
Is it possible to swap rear brakes from a 00 Si to a 00 Ex (coupes)? What parts are needed?
Thanks!
Old May 12, 2007 | 10:39 AM
bmoua's Avatar
Default Re: Rear brake conversion - 00 Si to 00 EX (Redz_EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redz_EX &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to swap rear brakes from a 00 Si to a 00 Ex (coupes)? What parts are needed?
Thanks!</TD></TR></TABLE>
yes bro, you will need the the entire trailing arm with the brake hoses and ebrake cables. It bolts right up. You will also need, well its recommended, the Si/DX/CX 4040 prop vavle and the Si 1 inch brake master cylinder.
Old May 12, 2007 | 10:41 AM
Redz_EX's Avatar
Default Re: Rear brake conversion - 00 Si to 00 EX (bmoua)
Much appreciated! Now to find one!
Old May 12, 2007 | 10:48 AM
bmoua's Avatar
look the classified bro, if not junkyard or online. the 99-00 si rear discs is not the only setup that will bolt up, the 94-01 integra rear discs will too.
Suspension/Brakes:
https://honda-tech.com/zerothread?id=152884- Putting X Brakes on Y Car
https://honda-tech.com/zerothread?id=514109- 96-97 JDM ITR 4 Lug Brake Information
https://honda-tech.com/zerothread?id=811892- ITR 4 Lug onto EK
https://honda-tech.com/zerothread?id=514109- ITR Brake Thread
https://honda-tech.com/zerothread?id=333061- Five Lug Conversion
https://honda-tech.com/zerothread?id=1036267- GSR Suspension into EG
https://honda-tech.com/zerothread?id=812062- Integra Rear Discs onto EG
https://honda-tech.com/zerothread?id=820484- Full Brake Swap for EG
https://honda-tech.com/zerothread?id=641639- EK Rear Disc Conversion
https://honda-tech.com/zerothread?id=1513752- How to put X Brake Setup on an EK
https://honda-tech.com/zerothread?id=641639- Complete Rear Disc Brake Conversion
https://honda-tech.com/zerothread?id=1030365- Integra Brake Swap
http://home.socal.rr.com/civic...x.htm- Cutting Away Old Control Arm Bushings and Using New Ones
https://honda-tech.com/zerothread?id=490117- Tie Rod End Removal
https://honda-tech.com/zerothread?id=1031874- Changing Tie Rod Ends
http://home.earthlink.net/~civ....html- Bolt and Washer Camber Fix
https://honda-tech.com/zerothread?id=481704- Jim Fab Traction Bar Install
https://honda-tech.com/zerothread?id=555391- HX Wheels on GSR or Si
https://honda-tech.com/zerothread?id=861481- Rear Lower Tie Brace Install
https://honda-tech.com/zerothread?id=972851- Front Tower Bar Install
https://honda-tech.com/zerothread?id=1079213- Lower Tie Brace Install
https://honda-tech.com/zerothread?id=1078663- Coilover Sleeve Install
https://honda-tech.com/zerothread?id=1278794- Installing Lowering Springs
https://honda-tech.com/zerothread?id=600967- NSX Calipers
https://honda-tech.com/zerothread?id=864784- Brake Rotor Replacement
https://honda-tech.com/zerothread?id=1317231- Quaife Steering into EG
https://honda-tech.com/zerothread?id=1427142- Shock/Strut Removal of EG
https://honda-tech.com/zerothread?id=1484555- Integra GSR Sized Brakes While Keeping Stock DX Civic Knuckles
https://honda-tech.com/zerothread?id=1437513- Blank vs. Cross Drilled Rotors
Old May 12, 2007 | 03:05 PM
excivicboy96's Avatar
dont the si and the ex share the same MC?
Old May 12, 2007 | 03:13 PM
philosofy1's Avatar
Default Re: Rear brake conversion - 00 Si to 00 EX (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">dont the si and the ex share the same MC?</TD></TR></TABLE>
i believe so too.
not only does the 94-01 integras work, but so does the 90-93 integras, 92-95 civics. those are the ones that were equipped with rear discs of coarse.
Old May 12, 2007 | 05:29 PM
egb18c5's Avatar
Default Re: Rear brake conversion - 00 Si to 00 EX (philosofy1)
dont forget the 4040 prop valve
WhiteNess
Oct 25, 2006 09:03 PM
klomast3r
Jan 30, 2006 11:38 PM
syked
Dec 30, 2005 11:37 AM
