ej1 tire size????? help 16in enkei rims what
205/50.... dont do 205/45... cuz the profile is a little small which makes the ride a little more harsh and can bend the rim if you hit a big pothole... so just go with regular lo pro's like 50 or 55
that speedometer thing is overrated... you can barely tell the difference on the speedo... i have put 16's on my car before and i didnt even see the difference on the speedo so i dont really pay much mind 2 the whole speedo thing... its not a big difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">Beside the factory speedo isn't accurate to began with.</TD></TR></TABLE>
^^^ very tru... a lot of people dont know this
I'm actually more worry about how low the op is. If he is going to use 50 or 55. There may be an issue with rubbing the fender.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">I'm actually more worry about how low the op is. If he is going to use 50 or 55. There may be an issue with rubbing the fender. </TD></TR></TABLE>
what do u mean... that it will rub with the 55? i know it will def. rub wit 60 but it all depends if the car is lowered
Modified by Midori Green at 11:02 PM 5/11/2007
