heater core leak 94 sol
Old May 11, 2007 | 08:42 PM
Del Sol on Steroids's Avatar
Default heater core leak 94 sol
Stuck in traffic for the first time this summer, and had my feet all wet with radiator fluid. I have a chilton book, but not clear on how to replace. Is the core still near the glove compartment, or does anyone know manuls other than chilton's.
Old May 11, 2007 | 08:44 PM
turbociviccoupe's Avatar
Default Re: heater core leak 94 sol (Del Sol on Steroids)
dont have a manual but the core isnt behind the glove....it more like behind the dash where the radio and climate control is
Old May 12, 2007 | 06:54 AM
Default Re: heater core leak 94 sol (turbociviccoupe)
damn, I have to remove the dash. Damn, Has anyone removed the dash before. Is it a bitch to remove?
Old May 12, 2007 | 08:00 AM
samba_green_sol's Avatar
its really not too bad, its 4 bolts...ill see if i can find a write up for you
Old May 12, 2007 | 11:21 AM
Default Re: (sososlodelsol)
thanks, I really need.
Old May 12, 2007 | 08:45 PM
no luck finding one, but when i pulled mine out of my sol (first time to ever pull a dash) it took me about 20 minutes
Old May 12, 2007 | 08:53 PM
muasboi's Avatar
yup, its actually quite easy to take off..looks intimidating though, but don't be fooled :D
it took me ~20 hours to do my heater core..grab a case of beer and get to it!!
i didn't get it at first too, but re-read it, and it'll make sense..
importfan0103's Avatar
for quick fix until you have time read what i wrote in this post
https://honda-tech.com/zerothread?id=1979409
Old May 13, 2007 | 07:25 PM
Default Re: (importfan0103)
Hey, if it works for now, I'll do it. Just incase I decide to give up, before I completely destroy the dash, how many hours will a garage charge me?
Old May 14, 2007 | 09:34 AM
i have no idea man, the dash if your not aquainted with it can take a while to do. im from mass and just by passing the heater core until you have time is what i would do man.... its only gunna get warmer ya know
Old May 14, 2007 | 11:24 AM
97ShLude's Avatar
Before you rip the dash out, check the a/c drain line that runs right under the glove box. I thought that the heater core was leaking in a del sol I was working on because the floor was just soaked all the time, but after a quick look up under the glove box I saw that the a/c evaporator drain was unhooked. One small hose clamp and leak was fixed!
nemesis25
Jun 20, 2009 05:09 PM
4gen5thtime
Mar 24, 2009 01:44 PM
iceman7329
Feb 7, 2007 03:53 PM
tornad0
Mar 20, 2005 04:24 PM
lostsurfer00
May 13, 2002 12:45 PM
