loose shifter
Old May 11, 2007 | 08:06 PM
japcat's Avatar
Default loose shifter
i got a 1991 crx hf with a b18 ls motor in it. The shifter is real loose. If i have it in gear i can still move it around. I searched around and is it the Shifter Stabilizer Bushings? People said that it will take the slop out of the shifter. I just want to make sure before i buy it. Also will the Shift Linkage make it loose? Do they usualy go bad?
Old May 11, 2007 | 08:32 PM
RedEfGoKart's Avatar
Default Re: loose shifter (japcat)
Yes, it is probably your shifter bushings. I have the same problem with my 16 year old ef. I just got mine in and will install them tomorow. and dont worry about the cost, I got my Energy suspension Bushings for $10. Summit racing has them for like $13 i think. usualy this will take out 99% of the slop in the shifter. as for wheather or not the linkage can go bad, unless it has been hit/bent by bottoming out (really hard) which is highly unlikely they dont go bad. Atleast i have never seen it happen.
Jonknee's Avatar
I bought a shifter stabilizer kit off Energy suspension for i think 17? and it fixed the loose shifter problem.
Old May 11, 2007 | 08:35 PM
japcat's Avatar
Default Re: loose shifter (Jonknee)
cool thanks i just wanted to make sure. i will order some right now. well i got another question. My first and second gear is to the left a lot. It is a lot different compare to any other car i drove before. What could be that problem?
Old May 13, 2007 | 09:07 AM
boosted timebomb's Avatar
its probably the u-joints in your shift linkage, the bushings will deteriorate over time and cause the problem your talking about. the ES bushings will help to a point but wont completely cure your problem
Old May 13, 2007 | 09:20 AM
RAB's Avatar
RAB
Default Re: loose shifter (boosted timebomb)
I have this problem, i.e. while in gear the stick wiggles. I just changed my SHIFT LINKAGE bushings yesterday with the energy suspension kit. My observations, the shift i.e. throwing it in gear feels solid. HOWEVER there is still some wiggle and slop while the car is in gear. Just my observation.
Old May 25, 2007 | 10:30 PM
you either have bad bearing on the shifter its self, (ther are little spacers and when they wear out the shifter will have slop) if so time to get a new shifter good excuse for short shifter. or wher the ball protion of your shifter is there is another bushing there, you will need to replace it. Call Energy and they can get it for you i cant rember what it is actually called a buddy had this problem.
Old May 25, 2007 | 10:42 PM
.Manny.'s Avatar
Touching My Member
Default Re: (RedEfGoKart)
could also be your u joint. check it for play
DOUBLExDEUCEx22
Jul 8, 2009 02:12 PM
jacoop86
10
May 23, 2006 11:53 AM
eluder33
Nov 20, 2004 03:05 PM
STHPERFORMANCE
Jul 6, 2003 07:28 PM
MrSmith
Aug 7, 2001 07:39 AM
