Civic 92 DX Hatchback idle problem
Old May 11, 2007 | 08:01 PM
kos99ngel's Avatar
Default Civic 92 DX Hatchback idle problem
I recently did a tune up to my EG its has a stock d15b7 in the morning its turns on fine and it idles fine but after its has warm up and for instance I get to a stop sign or leave the car running it idles its revs up and then its get back to its normal RPM then it goes back up after 5 minutes its get back to normal I am then I drive it for a while and I stop it does the same thing again someone told me the spark plugs but I change them recently brand new OEM I bought them from the Honda dealer can it be my MAP
Old May 11, 2007 | 08:10 PM
kaiba's Avatar
Default Re: Civic 92 DX Hatchback idle problem (kos99ngel)
Change your iavc filter.
Old May 11, 2007 | 08:15 PM
kos99ngel's Avatar
Default Re: Civic 92 DX Hatchback idle problem (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba &raquo;</TD></TR><TR><TD CLASS="quote">Change your iavc filter. </TD></TR></TABLE>
WOuld it be because I don't have my air box i don't have a intake they stole it when i got my car stolen i haven't got around to get another intake....
Old May 11, 2007 | 08:24 PM
kaiba's Avatar
Not the intake filter.
Old May 11, 2007 | 11:50 PM
civicsi401's Avatar
could be a number of problems i would check the map sensor as well as bleed the cooling system air in the cooling can cause a serg . could also be a cracked vac line somewere
Old May 12, 2007 | 05:05 AM
excivicboy96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kos99ngel &raquo;</TD></TR><TR><TD CLASS="quote">
WOuld it be because I don't have my air box i don't have a intake they stole it when i got my car stolen i haven't got around to get another intake....</TD></TR></TABLE>
You have a filter on it right?
Old May 12, 2007 | 05:59 AM
kos99ngel's Avatar
Default Re: Civic 92 DX Hatchback idle problem (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">
You have a filter on it right?</TD></TR></TABLE>
Do u mean by as for my intake i don't have any filter i recently put it back together i haven't gotten around to get myself a cold air intake
Old May 12, 2007 | 07:07 PM
viahiptop's Avatar
I had a similiar problem. I got rid of it by replacing the TB gasket, cleaning the TB, new o-rings for my map and iacv.
david420
17
Aug 14, 2012 06:23 AM
Hatchbacker
Oct 10, 2010 07:20 AM
byronl
13
Mar 21, 2005 09:57 PM
7808
May 19, 2004 09:47 AM
