Header on now check engine light
Old May 11, 2007 | 05:07 PM
ricanzxrebel's Avatar
Default Header on now check engine light
First off I wanted to hey to all of you. I tried searching for the answer but could not find an answer so please try not to flame on the noob.
I have a B16a w/ hydraulic tranny. I put on a 4-1 header with 2.5" collector and I threw a CEL light (code 41 which I understand is 02 sensor error). Is this normal and how do I fix it? thanks guys
Old May 11, 2007 | 05:10 PM
chrisw85's Avatar
is the O2 sensor still good, did you reuse it or get a new one?
Old May 11, 2007 | 05:19 PM
jellydoughnutt's Avatar
Default Re: (chrisw85)
O2 sensors are very sensitive, if you handled it rough or put any kind of inpact on it then its dead. if this is the case you will need to buy a new one. did you tighten it all the way in? make sur eits plugged up?
Old May 11, 2007 | 06:09 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (jellydoughnutt)
What else could it be?
o2 sensor ftw.
Old May 11, 2007 | 09:23 PM
I reused the old one, but no the O2 was not handled rough at all.
So basically all that could be wrong with it is that I need a new O2?
Old May 11, 2007 | 09:26 PM
Midori Green's Avatar
Default Re: (ricanzxrebel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricanzxrebel &raquo;</TD></TR><TR><TD CLASS="quote">I reused the old one, but no the O2 was not handled rough at all.
So basically all that could be wrong with it is that I need a new O2? </TD></TR></TABLE>
pretty much... because there is nothing electrical on the exhaust manifold therefor nothing can set off the cel except the o2 censor
Old May 11, 2007 | 09:46 PM
Default Re: (Midori Green)
I do understand that. I was just wondering if the CEL was on because the O2 might have sensed a difference from once being at the top Y to being at the collector. Well if thats the only prob then Im glad, thanks guys
Old May 11, 2007 | 09:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricanzxrebel &raquo;</TD></TR><TR><TD CLASS="quote">I do understand that. I was just wondering if the CEL was on because the O2 might have sensed a difference from once being at the top Y to being at the collector. Well if thats the only prob then Im glad, thanks guys</TD></TR></TABLE>
yea... u already know how cheap an o2 censor is
Old May 11, 2007 | 10:08 PM
yeegsr's Avatar
Default Re: Header on now check engine light (ricanzxrebel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricanzxrebel &raquo;</TD></TR><TR><TD CLASS="quote">First off I wanted to hey to all of you. I tried searching for the answer but could not find an answer so please try not to flame on the noob.
I have a B16a w/ hydraulic tranny. I put on a 4-1 header with 2.5" collector and I threw a CEL light (code 41 which I understand is 02 sensor error). Is this normal and how do I fix it? thanks guys</TD></TR></TABLE>
I think everytime you removed the o2 sensor you first need to disconnect the battery, not sure if you did that or not, but anyway too late.
you're out of luck...the last thing you can try is to clean thatretarded O2 sensor with some evaporable spray from Kragen or Autozone and snap it back on, maybe you're lucky if not, try a new one.
Modified by yeegsr at 11:33 PM 5/11/2007
tcbn
Mar 10, 2006 01:25 AM
Themouse
19
Feb 1, 2006 04:17 PM
EF4lyfe
Mar 1, 2005 09:00 AM
djtech
Feb 6, 2003 05:34 PM
Buckshot
Jul 24, 2002 12:43 AM
