i need all info for a swap on my crx 1.5 dpfi to a d15b vtec
Old May 11, 2007 | 02:02 PM
9c1r1x.5's Avatar
Default i need all info for a swap on my crx 1.5 dpfi to a d15b vtec
hey i have a 1991 crx with the d15b2 dpfi engine, now i really need a new motor in my car its smokin bad, so i recently came across a d15b jdm vtec engine, with the tranny, engine harness, and ecu, now what do i need to do this swap, i kno theres wiring issues i just dont know what, please somebody help me im hurtin for a motor and id like to get this done asap, all information is appreciated thanks
Old May 11, 2007 | 02:15 PM
jlicrx's Avatar
Default Re: i need all info for a swap on my crx 1.5 dpfi to a d15b vtec (9c1r1x.5)
this is the easy way:
http://rywire.com/store/8891-c...af7b7
Old May 11, 2007 | 02:37 PM
janz3n's Avatar
Default Re: i need all info for a swap on my crx 1.5 dpfi to a d15b vtec (jlicrx)
SEARCH
Old May 23, 2007 | 10:58 PM
C_I_V_I_C_V_T_E_C's Avatar
Default Re: i need all info for a swap on my crx 1.5 dpfi to a d15b vtec (janz3n)
u need the wiering harness, most likely an ecu, and i think only a little time. i think thats it but i could be wrong
Old May 24, 2007 | 01:32 AM
HondaPartsHero's Avatar
Technical Hero
http://fourthgenhatch.net/mpfi.html
Then you'll need to then run wiring for VTEC solenoid and buy a pressure switch or bypass it because the JDM \D15B doesn't come with one. Swap over the block mount on the timing belt side from your D15B over to the new D15B. Extend the wiring for the fan switch from the back of the block to the thermostat housing. Get a OBD0-1 distributor and ECU adapter to run a P28 OBD1 ECU or comprable. Run wiring for 4 wire oxygen sensor.
Old May 24, 2007 | 11:15 AM
Default Re: i need all info for a swap on my crx 1.5 dpfi to a d15b vtec (HondaPartsHero)
dosen't he also have to do dpfi to mpfi conversion
Old Jul 17, 2012 | 06:02 PM
DatCrx89's Avatar
hey i got a 89 honda crx si. did motor swap to d15b and already change computer to p28 and distibutor.. having problem with temperature gauge and fan working. what do i need to do
flash100
Oct 25, 2014 07:47 PM
mmaboxer02
Apr 26, 2010 03:47 PM
hondadrvr793
Jan 2, 2007 10:21 PM
Naoh_97
10
Feb 14, 2005 10:40 AM
miketurbohonda
Sep 24, 2004 08:12 PM
