valve adjustment or bent valve?
Old May 11, 2007 | 01:52 PM
bseries_beast's Avatar
Default valve adjustment or bent valve?
I recently did a valve adjustment on my 96 civic with a b18b swap. The valves were ticking pretty loud but its even louder now since ive done the valve lash adjustment. I ran into one problem with the valve adjustment though i did all the cylinders in the correct order and they all worked out perfect until i came to cylinder 2, i could not get the feeler gauge to fit though the exhaust valve at all. Im gonna try doing the adjustment again this sunday. Is there a chance that maybe my exhaust valve on cylinder 2 could be slightly bent or what could it be? please help
Old May 12, 2007 | 12:39 PM
Default Re: valve adjustment or bent valve? (bseries_beast)
bump
Old May 12, 2007 | 12:44 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseries_beast &raquo;</TD></TR><TR><TD CLASS="quote">I recently did a valve adjustment on my 96 civic with a b18b swap. The valves were ticking pretty loud but its even louder now since ive done the valve lash adjustment. I ran into one problem with the valve adjustment though i did all the cylinders in the correct order and they all worked out perfect until i came to cylinder 2, i could not get the feeler gauge to fit though the exhaust valve at all. Im gonna try doing the adjustment again this sunday. Is there a chance that maybe my exhaust valve on cylinder 2 could be slightly bent or what could it be? please help</TD></TR></TABLE>
did you use the right gauge size?
also, are you sure that cylinder 2 was proper aligned? if it's not exactly at tdc then you will not feed the gauge through.
fwdupree
Jun 1, 2018 12:13 PM
NEDan
Honda Fit
Aug 4, 2017 06:30 AM
supersize
Jul 26, 2010 11:50 PM
twisted civic
Honda Civic (2001 - 2005)
Jul 26, 2008 05:32 PM
