problems with xs power cams!!!
Old May 11, 2007 | 01:21 PM
hondab16peru's Avatar
Default problems with xs power cams!!!
i buy a xs power camshaft stage 2...but i dont have the complet specs..my mecanics have problems....please someone else who had these cams or the complete specs??? my car is a honda civic b16a....
Old May 11, 2007 | 01:26 PM
Mr.EM1_EK's Avatar
Default Re: problems with xs power cams!!! (hondab16peru)
what is the problem with them? they don't fit right or something.
Modified by Mr.EM1_EK at 2:46 PM 5/11/2007
Old May 11, 2007 | 01:32 PM
Team RS2's Avatar
Default Re: problems with xs power cams!!! (Mr.EM1_EK)
xs power as in the cheap ebay turbo accserssories? yea dude those arent built with quality or power in mind, run out and get some sk2's
Old May 11, 2007 | 01:44 PM
95ProjectEJ1's Avatar
Default Re: problems with xs power cams!!! (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">xs power as in the cheap ebay turbo accserssories? yea dude those arent built with quality or power in mind, run out and get some sk2's </TD></TR></TABLE>
Or maybe XS Engineering?
GSRpoweredSI's Avatar
do not use those cams!!!! those cams will seriously screw up your roller rocker arms crush the rocker pads. they are actually factory regrinds. i tried running the same ones you probably bought off of e-bay for 275. right? the distributor notch is not cut properly. you will have to advance your timing too much. notch your alternator and turn it 90 degrees. do not run these. they are crap.
Old May 11, 2007 | 01:45 PM
i dont write very well the english i am from peru..i buy a xs power cams i have problems because i dont have the complete specs... how many grades in admision ..how many in scape...
Old May 11, 2007 | 01:47 PM
MR.johnson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondab16peru &raquo;</TD></TR><TR><TD CLASS="quote">i dont write very well the english i am from peru..i buy a xs power cams i have problems because i dont have the complete specs... how many grades in admision ..how many in scape...</TD></TR></TABLE>
im sorry i think you should have someone else type for you.
Old May 11, 2007 | 03:57 PM
ATYPR's Avatar
Default Re: problems with xs power cams!!! (MR.johnson)
https://honda-tech.com/zerothread/1977953
Old May 11, 2007 | 05:14 PM
i dont have the complete specs!!!!!!! of this cams
Old May 11, 2007 | 05:56 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondab16peru &raquo;</TD></TR><TR><TD CLASS="quote">i dont have the complete specs!!!!!!! of this cams</TD></TR></TABLE>
consider that a blessing in disguise. ditch those cams before you do serious harm to your engine.
DOHCgarage919
Sep 8, 2007 08:42 PM
GS-Rteg
Feb 27, 2007 08:47 PM
athbaseball23
Jul 23, 2006 03:47 PM
Shaun
May 11, 2006 08:55 AM
You Know I Got SOL!
Apr 24, 2006 03:44 PM
