idle problem
Old May 11, 2007 | 08:14 AM
94HONDAHEAD's Avatar
Default idle problem
ok just got my car fixed and it idles at 2k but then goes slowly down to 1500. Also when I am driving and get to a stop light it goes down to 1000 then upo to 2000 a few times then stays at 2k and then goes slowly to 1500. Other times on the freeway and get off i put it in neutral and it well surge form 1000 to 2000 and then do the same at a stop light as stated before. My car is a 1994 Honda Civic Ex with a b16a. I have tried adjusting at the throttle cable nothing and cleaned my ivac out really well checked connections nothing. thanks for any help.
Old May 11, 2007 | 08:41 AM
Luserkid's Avatar
Default Re: idle problem (94HONDAHEAD)
Try changing your intake manifold and throttle body gasket.
Old May 11, 2007 | 08:42 AM
deadline's Avatar
https://honda-tech.com/zerothread?id=558236
might help
Default Re: idle problem (Luserkid)
ok thanks yeah i reused the same ones I had on there before.
Old May 11, 2007 | 09:02 AM
97Ej6mike's Avatar
Its the IAC, replace it
Old May 11, 2007 | 09:46 AM
paddy138's Avatar
Default Re: (97Ej6mike)
the sensor on the back of the throttle body.replace it, the same happened mine and i got a second hand throttle body with it attached and its going fine now
Old May 13, 2007 | 08:22 PM
Default Re: (paddy138)
Tried changing the tps and got a code put back the old one on and it was gone. But it idled the same and i pushed down the plunger that is under the TB thing all the way.
Old May 13, 2007 | 10:02 PM
vi3tromanc3r's Avatar
Default Re: (94HONDAHEAD)
got da same problem, but not as high, mines from 1000 to 1500. i adjusted the screw for idle on the TB and when its low enough it'll stop doing it but my car would idle really low. like at 200-300. my cars not throwing any cels either. if you change anything and it fixes the problem lmk might be the same for my car.
Old May 14, 2007 | 05:34 PM
Default Re: (vi3tromanc3r)
Will do I am gonna try changing out my iacv and see if it helps because I got no vacum leaks. But might start changing hoses just to make sure that isn't it.
import-tooner
Jul 19, 2013 06:39 AM
DO/\/\O
Jul 26, 2011 01:44 AM
1989sircrx
10
Mar 27, 2010 04:26 PM
jbell
Sep 26, 2005 11:04 AM
InfamousRS
Jul 4, 2003 01:20 PM
