getting a code #9 after mpfi swap need help......
Old May 11, 2007 | 07:07 AM
jcyaj's Avatar
Default getting a code #9 after mpfi swap need help......
i got done with an mpfi swap from a dpfi and i got an code 9... i checked all the wiring and everything is good wat can i do? but on the b clip i have an b12 in place there was a white wire there. b11 and b 10 and b18 are empty... what else can i do????
Old May 11, 2007 | 04:03 PM
N_A_is_best's Avatar
Default Re: getting a code #9 after mpfi swap need help...... (jcyaj)
on the distributor swap the 2 white wires it might help out
Old May 11, 2007 | 04:49 PM
janz3n's Avatar
Default Re: getting a code #9 after mpfi swap need help...... (N_A_is_best)
most likely your distributor took a **** on you.
Old May 15, 2007 | 08:40 AM
jcyaj's Avatar
if the distributor is bad then the car would not run but its run great...if i changes the wires i get a code 4 then change it back i get a code 9 again..
Old May 15, 2007 | 12:05 PM
janz3n's Avatar
your car would run if the distributor is bad. trust me. i had a code nine and did the troubleshooting that used to work in the faq page and figured out my distributor was bad.
Old May 15, 2007 | 08:17 PM
jcyaj's Avatar
aright i'll give that a try thanks..
Old May 15, 2007 | 08:50 PM
julioboostamante's Avatar
b10 and b12 are the cps right ? c1 and c2 are the cam anlge.
check to make sure those wires arent mixed up. and that the b10 and b12's are going to where they should.
Old May 15, 2007 | 11:35 PM
90sedan's Avatar
Did you splice into the factory wire that was at b12? Or did you depin it and repin the new wire?
If you spliced into it, redo the wiring. That should fix the problem.
Old May 16, 2007 | 04:43 PM
jcyaj's Avatar
i changed a new distributor and still got same code i get a custom made one to just plug and play but its not working...all the wire are in the right spot i'am sure of it cause it wouldn't work if i switch it around the car won't start...
Old May 16, 2007 | 05:54 PM
janz3n's Avatar
who made this "custom wiring harness" that could be your problem. its 10x's easier to do the wiring yourself.
Old May 16, 2007 | 06:45 PM
90sedan's Avatar
Default Re: getting a code #9 after mpfi swap need help...... (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">who made this "custom wiring harness" that could be your problem. its 10x's easier to do the wiring yourself. </TD></TR></TABLE>
Unless it's from rywire
But yes, knowing that it was done right would save a lot of hassle.
Old May 16, 2007 | 08:14 PM
jcyaj's Avatar
this guy that does it for many shops with swap i bought two from him before and those works great just this one and i don't know why he traded me an new too still doing the same thing..i'am out of ideas i have four different ecu the crx one works with no code but runs bad and can't stay runing..
Old May 16, 2007 | 09:34 PM
HiProfile's Avatar
There's a good chance that any added wires for the 'new' sensor in the dizzy aren't good enough. I had to replace my wires twice, 1st time it just wouldn't work, 2nd it worked for a while (heavy-duty wires), 3rd I just got tired and ran 14ga stereo wire for them.
Old May 16, 2007 | 09:43 PM
90sedan's Avatar
Default Re: getting a code #9 after mpfi swap need help...... (HiProfile)
Honestly, keep double checking your wiring. You will find the problem.
Replacing the wire might be a good idea. What guage are the wires?
Modified by 90sedan at 10:56 PM 5/16/2007
Old May 30, 2007 | 07:10 AM
misha's Avatar
Default Re: getting a code #9 after mpfi swap need help...... (90sedan)
yea, check your b12 again. And it is easier to do all of it yourself...
Good luck
Old May 30, 2007 | 05:14 PM
Default Re: getting a code #9 after mpfi swap need help...... (misha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misha &raquo;</TD></TR><TR><TD CLASS="quote">yea, check your b12 again. And it is easier to do all of it yourself...
Good luck </TD></TR></TABLE>
hell yes!
its about 6 wires in the ECU side that need to be moved/ added
2 for the CPS
2 for te CAS
2 for the added injectors ( if you wanna be gangsta about it do all 4 straight from the ECU to the injectors.
engine bay is just the dizzy wires, Cam angle sensor wire and the injector box.
Ct93CB7
Oct 21, 2010 09:26 AM
turbob18si
Dec 3, 2006 04:02 PM
cjwarren4dcivic
14
May 1, 2006 11:25 AM
Schaz
May 16, 2005 07:34 PM
88fgfd
27
Jul 8, 2004 05:40 PM
