removing my A/C
Old May 11, 2007 | 06:59 AM
FOOLS_Si's Avatar
Default removing my A/C
i want to remove my A/C because it dosent work for one and it would just clear up some room and weight. i drive a 99 honda civic si B16 and was wondering is there anything that i should do b4 i start yankin parts off and what all exactly do i take off?
Old May 11, 2007 | 07:07 AM
yoffer's Avatar
Banned
well you want to remove all the a/c freon (if there is any) but its not exactly legal. But anyway, just stick a flathead screwdriver into the "L" hole on the a/c lines and let it out. Then you can start "yanking" it out.
Old May 11, 2007 | 07:09 AM
92'si's Avatar
Default Re: (yoffer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoffer &raquo;</TD></TR><TR><TD CLASS="quote">well you want to remove all the a/c freon (if there is any) but its not exactly legal. But anyway, just stick a flathead screwdriver into the "L" hole on the a/c lines and let it out. Then you can start "yanking" it out.</TD></TR></TABLE>
WTF dude??
just have an ac shop take it out if you cant rent the machine... cant cost more than like 20 bucks
Old May 11, 2007 | 07:15 AM
FOOLS_Si's Avatar
Default Re: (92'si)
what all do i take out? do i remove the belt, pulley, block that pulley is connected to etc.
Old May 11, 2007 | 07:20 AM
92'si's Avatar
Default Re: (FOOLS_Si)
you got the condensor, compressor, lines, and that little can thingy.. whats it called? and if you get serious you can take out your evaporator box (under your dash)
Old May 11, 2007 | 07:33 AM
FOOLS_Si's Avatar
Default Re: (92'si)
it wont throw off my timing or anything because of the engine pulling onone less?
Old May 11, 2007 | 08:54 AM
FOOLS_Si's Avatar
on less pulley and belt?
Old May 11, 2007 | 09:12 AM
instructor74's Avatar
There is no freon in that system. Honda stop using freon in ac in 1994 I beleave. Your system will be charged wiht r134 witch is not freon
Old May 11, 2007 | 10:01 AM
FOOLS_Si's Avatar
Default Re: (instructor74)
will it throw off my timing or anything by my engine pulling on one less belt and pulley?
Old May 11, 2007 | 10:23 AM
FOOLS_Si's Avatar
bump
Old May 11, 2007 | 11:47 AM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOOLS_Si &raquo;</TD></TR><TR><TD CLASS="quote">will it throw off my timing or anything by my engine pulling on one less belt and pulley?</TD></TR></TABLE>
No.
-Championship-
Jan 17, 2007 08:59 PM
vtec92lude
Nov 3, 2004 11:11 AM
hondamagic98
May 25, 2004 07:17 AM
J_J
11
Feb 8, 2004 07:56 AM
LD_EGSICK
15
Aug 24, 2002 08:46 AM
