Need help replaceing head.
Old May 10, 2007 | 08:27 PM
89crxsiVT's Avatar
Default Need help replaceing head.
I am replacing the head on my d16a6. I know i need a head gasket, but what else. I wasn't the one that pulled the head off. I know the motor has 78,000 on it.
Old May 10, 2007 | 09:31 PM
garageEF's Avatar
Default Re: Need help replaceing head. (89crxsiVT)
new headstuds
Old May 11, 2007 | 12:17 AM
Redline130's Avatar
You might as well change the timing belt, water pump, timing belt tensioner, and any other parts that would normally be a pain to change with the head on.
Old May 11, 2007 | 08:51 AM
89crxsiVT's Avatar
Default Re: Need help replaceing head. (Redline130)
Ok i was told that head studs were going to be needed so, were ia a good place to pic them up.
Old May 11, 2007 | 10:05 AM
msinsky14's Avatar
u might as well get some ARP head studs while ur at it. theyre very strong and last forever. and pick up a metal headgasket too, it'll keep the compression up and be a good idea in case u ever run boost or nitrous
Old May 11, 2007 | 10:50 AM
dr_latino999's Avatar
Default Re: Need help replaceing head. (msinsky14)
OEM headstuds = 70$ for 10 bolts that recommended to be used only once.
ARP Headstuds = 100$ for 10 studs that are rated for many uses and umpteen times stronger. BTW, studs make putting the head on so much easier.
Now on the headgasket, the stock A6 one is paper and is a pita to clean off. The Y8 head gasket is 30$ or so from the dealer and you get the benefit of a metal contact surface; the compression increase isn't anything to cry home about either.
Old May 11, 2007 | 12:29 PM
msinsky14's Avatar
Default Re: Need help replaceing head. (dr_latino999)
yea I know its not gonna be a huge difference, just that its a good idea while ur at it
DelSol-B18
Sep 8, 2012 06:24 PM
modernvisionscc
Aug 3, 2007 12:06 PM
BlackHXCoupe
Dec 22, 2006 07:08 AM
ham
Jul 8, 2006 08:46 PM
RTW DC2R
Sep 9, 2002 01:58 PM
